Acer AL1717 17" LCD Monitor Logo
Posted on Jan 08, 2010
Acer AL1717 lcd plss help
My acer AL1717 always says no signal in a middle of a game plsss help... and is it a Vido card problem?
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jul 31, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
6599
Points
Your resoulutions are Hz are too high in the game settings for your monitor. Reinstall your game.
Why in my Acer monitor AL1717 comes vertical lines in middle of the screen ?
Try updating your display driver and also try with another monitor cable, in case its broken.
Why Vertical lines in the middle of the screen ??
This could be your graphic card is aging or the Hard Drive or even the monitor saying goodbye. Troubleshoot with another monitor, you will be able to narrow it down more. Good luck!!!
My AL1717 monitor shows a flickering power signal (blinks off & on) but shows black screen and nothing else. Thank You
Most likely a problem with internal capacitors either blown or swelling or leaking. Can be repaired by replacing the faulty capacitors but recommended that this be carried out be a qualifed technician
Normally, when the monitor is switched on, a blue screen is shown momentarily, with 'acer' right in the middle, before it shows the image that the computer is sending. But now, the screen does not show...
It sounds like either a bad signal input , possibly from a loose plug on the cable from the PC or bent pins on the plug / the video graphics card in the PC/ or the settings on the monitor need adjustment. Use the OSD (On Screen Display)
First check to make sure both ends of the cable from the PC to the monitor are not damaged and are seated good & tight.
If those are fine then unplug both cables from the monitor & leave unplugged for 10 minutes or so to see if the screen has an automatic reset.
If that does not work then use the monitors OSD (On Screen Display) to adjust to default settings. If that does not work, plug the monitor into another known good PC.This will tell you right then if its the monitor or "Your" PC.
__________________________________________________________
Here is your manual if needed
http://www.retrevo.com/support/Acer-AL1717-Monitors-manual/id/719ag107/t/2/
My adpater is unavailable what should i do plsss help me
Go to control panel>system>hardware>device manager and find your display adapter. Right click on it and choose properties. If it is disabled, choose to enable it. There is also a troubleshooter there to help you find problems with the device. It is possible you will need to update the device drivers, in which case see Vista here and xp here
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
2helpful
3answers
Acer al1717
Please try loading monitor specific drivers.Many of the time the monitor is recognised as "Plug and Play Monitor".
Samir
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
