Question about Kitchen Appliances - Others
My Seal-a-meal won't heat up to seal the bag. The motor works and the ''hands free'' light comes on, but the heating strip is cold to the touch.
Posted by mwspds on
hmkopp
Just bought mine - how long does it take to heat up? it's been 10 minutes already, I don't feel any heat. no lights coming on, but when I pushed on the lid, the vacuum started, so I know it's "on"
Posted on Jan 31, 2015
1 Related Answer
mc1bean
Mike Cairns
  • 3053 Answers
SOURCE: My Seal-a-meal won't heat up
There is two places this problem can be. First of all, I would see if you can at the switch itself, sometimes if you of course unplug unit. See if you can get to the switch it could be just a bad contact where it triggers the Teflon coating heating strip. Now most likely it is there, but however these Teflon coating heating strips are prone to go out, they are cheap and flimsy and it does not take much to damage them like a spot or tear, or ware mark. It tends to break the circuit. However first try and make sure your switch is working and triggering the heating element, then if not, you need to order a new heating strip from manufacturer. Sometimes more hassle and expense then replacing unit itself. Thanks Mike
Posted on Sep 16, 2011
After hands-free red light for sealing turns on, why does it take a long time to start sealing?
Seal-a-Meal FSSMSL0160-000 Vacuum Sealer - Amazon.com
www.amazon.com > ... > Vacuum Sealers
Amazon.com, Inc.Handy indicator lights for "Hands-Free" and "Sealing", plus Open/Cancel button. Keep your busy kitchen running smoothly with help from this easy-to-use Seal-a-Meal ... With its sleek, straightforward design, the compact appliance effectively ... After completing the vacuum sealing cycle, both the motor and the "Sealing" ...Missing: red
Amazon.com: Rival Vacuum Sealer: Kitchen & Dining
Amazon.com, Inc.
Rating: 3.6 - ‎233 reviews
Online Shopping for Kitchen Small Appliances from a great selection of ... Rival FSFGSL0150-015 3 Step Vacuum Sealer w/ Bag Starter Kit ... You push down....wait for Hands-Free light & Sealing light to go on....let go....wait for lights to turn off. ...After a couple of bags were done, I started having an issue in which the unit did ...Missing: red
Amazon.com: FoodSaver FSFRSH0051 FreshSaver ...
Dec 25, 2015 | Kitchen Appliances - Others
Not sealing the bag
My husband is a fisherman here in Key West and swears by his vacuum sealer, but he was about to throw it through the window last week when it stopped working.
The motor would just run and run, but the vacuum never kicked on.
I found an answer online that solved his problem and may help some, but not all of you.
Apparently, it was all about bag placement for us.
When you're just trying to seal one end of the plastic to make a bag from a roll, make sure the end of the plastic is just on the front, flat heat seal strip and is NOT touching the black, rubber gasket that lines the vacuum tray, Also, make sure the end is NOT hanging over the gasket and into the vacuum tray.
Apparently, the machine was sucking, but air was constantly come through the other, open end.
Once you've sealed a bottom into your bag and have added your contents, then you put the open end (after making sure it's dry) all the way into the vacuum tray.
Hope this helps, good luck! I was so happy to find an answer online that I figured I'd share it with others.
Here's to fresh fish!
Mar 30, 2014 | Rival VS230 Seal A Meal Vacuum Food Sealer
V3840 heat strip doesn't get hot
Could be the heating element (wire that gets hot enough to melt plastic) is going bad, how long have you been sealing bags with the unit? If you have used it for some time there is the possibility of build up plastic/residue on the the wire or the surface that actually comes in contact with the bag as I would suspect there is a coated surface the element heats up as opposed to the element / wire coming in contact with the plastic itself!
Nov 19, 2017 | FoodSaver Vacuum Food Sealer - V3840
When I go to SEAL, it burns a small hole clear thru the bag. One little metal peice on the sealing strip has burned right thru the white heating strip, therefore, it isn't sealing completely.
You need new tape to replace the one presently covering the heat element. You can get a roll of it for just US$7.99. Look at the FixYa question "where [or how maybe] can I get a new tape." I think that you have to be sure that the heat element is flat. I bought a used unit with that problem and the element had somehow gotten bent. Ordered the tape this morning and the cost is worth the hopeful fix.
Jul 30, 2012 | Rival VS230 Seal A Meal Vacuum Food Sealer
Seal-a-Meal seal has blister on it
I think that you have the same problem that I have. The protective tape over the heating element [a strip in my case] has a hole in it and allows the element to come in direct contact with the bag. Also, the heating strip had a kink in it was was no longer flat. I carefully cleaned the heating strip and flattened it out as best I can. I have ordered some tape from : http://www.ebay.com/itm/170848027703?item=170848027703&viewitem=&sspagename=ADME:X:AAQ:MOTORS:1123&vxp=mtr to replace the defective one. A simple job.
Jul 17, 2012 | Rival VS230 Seal A Meal Vacuum Food Sealer
Unit will not heat and Hand free light will not come on.
My husband is a fisherman and swears by his vacuum sealer, but he was about to trthrow it through the window last week when it stopped working.
I found an answer online that solved his problem - apparently, it's all about bag placement.
When you're just trying to seal one end to make a bag cut from a roll, make sure the end of the plastic is just on the front, flat heat seal strip and is NOT touching the black, rubber gasket that lines the vacuum tray, Also, make sure the end is NOT hanging over the gasket and into the vacuum tray.
Oct 24, 2011 | Rival VS230 Seal A Meal Vacuum Food Sealer
Need to find a heat strip for seal a meal vz110
Model 750 seal a meal will not seal bags
Norm
Mar 09, 2010 | Food Processors
Seal-a-meal won't seal
Take apart and see if wires are connected That is what was wrong w/ mine. Soldered wire now works fine.
Mar 30, 2008 | Vacuums
Kitchen Appliances - Others Logo
1,371 people viewed this question
Top Kitchen Appliances - Others Experts
Marvin
Marvin
Irene Tulloch
john h
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
