Electric or gas dryer? Depending on where the ticking sound is coming from, without more specific information, many dryers use a timer within their dial for timed drying. If the switches are malfunctioning, the ticking of the "timer" can still continue. If you can hear a whirring sound, which would be the motor, then it may be the drive belt. If this is the case, then the ticking of the timer may be more noticeable due to it being quieter without the spinning drum.
If you have a gas dryer and the ticking is from below, then it may be the ignitor that's faulty. However, that shouldn't cause your dryer not to turn on. It that case the dryer would spin, but not get warm. With more information, I may be of better assistance.
could have a bad timer,when it stalls try tapping on the timer or wiggling the knob to see if it will start,there's a little motor on the timer that you hear ticking and it could fail.
the timer has internal cog teeth with works with an ecentric cam to keep the timer operating. the cam is working if ticking although a tooth appears to be broken keeping the timer to advance on its own
Make sure it has power. Then:Check the door switch.
A little lever sticking down through top right of door opening. If it is
not there you will need new door switch(sometimes the little lever
breaks off). If it is there and does not click when you press it in you
need a new door switch. if it clicks when you close the door
then you have a bad thermal fuse.The thermal fuse is found by taking
the back of the dryer off. The fuse is an oblong white plastic piece
with 2 wires attached.
Door switch part number 3406109 Thermal fuse part number 3392519
