Question about Philips 42PF9631D 42 in. Plasma Television
Philips 42PF9631D 42 in. Plasma Television TV wont turn on..I get the initial green power light, but it quickly goes to a flashing red light (flashes a series of 4 times). Philips tech support is a joke. local repair service wants $400 just to "look" at the set. HELP!
Posted by lejeunee on
Anonymous
    New Friend:
    Problem Solver:
  • 5 Answers
I would just do the capacitors its so easy you can do it yourself. i just did mine today and the tv works great.
Posted on Feb 05, 2010
Chi Chu
  • Philips Master
  • 8,457 Answers
Philip have alot power problems with their tv.Check power board for puff up parts like Capacitors,or rust in cracks or soldering.Changes parts or the whole power board.
Posted on Jan 08, 2010
Philips flat screen 42" flashing red light 7 times it stops for 5 seconds and 7 more flashes if i unplug and plug it a few time it will come on
my 42 inch phillips, i turn it on green light comes on for 10 sec then red light comes on and flashes 4 times then stops for 5 sec then repeats.
Apr 20, 2010 | Philips 42PF9631D 42 in. Plasma Television
Blinking red light and tv will not turn on.
problem on power supply , u may have 2 bAD capacitor
Apr 14, 2010 | Philips 42PF9631D 42 in. Plasma Television
Red light flashing in the front
Power supply board is dead.Replaced the power supply board will solved this problems.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 11, 2010 | Philips 42PF9631D 42 in. Plasma Television
Philips 42pf9631d/37 6 slow red flashes and 3 fast
6-7 blinks means there is an issue with the power supply...
I found a replacement for my 42pf9631d/37
Part # Lj44-00117A
at TSM Inc. for $110.95 with free shipping...
http://www.tristatemodule.com/p-10120-lj44-00117a-samsung-tv-module-power-supply.aspx
Jan 28, 2010 | Philips 42PF9631D 42 in. Plasma Television
Why wont my tv turn on? a red light just flashes
Right now, your TV is in " Protection Mode". A damaged part has occurred inside on one of the power supply boards. The red flashing light is a trouble code for a tech to trace the trouble circuit path.
If you have electronic experience with circuit boards, you can find a Service Manual for the TV on the internet for less than $20. This Service manual will have the schematics, red light codes, circuit diagram, and part number list you need to fix the board.
Oct 11, 2009 | Philips 42PF9631D 42 in. Plasma Television
Phillips 42 inch LCD 42PF9730A Redlight flashing
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
Jun 16, 2009 | Philips 42PF9631D 42 in. Plasma Television
7 red flashing lights, won't power up..
Check the power board for capacitors with the tops bulged up. They are 3300uf 10v. There are either 2 or 4 of them depending on your set.
Jun 01, 2009 | Philips 42PF9631D 42 in. Plasma Television
Check the power board for caps with the tops bulged up. 3300uf 10v.
May 16, 2009 | Philips 42PF9631D 42 in. Plasma Television
TV will not turn on, the light goes from green to red.
I own the same model. You have 1-2 Blown Capacitors. Take off the back cover, And look towards the center of the main power board. Look towards the center of this, and there are 2 capacitors side by side. You should see them swollen at the tops, even maybe a little black residue that has come out. I soldered on 2 new ones, and bingo! I would suggest replacing them both.
Dec 13, 2008 | Philips 42PF9631D 42 in. Plasma Television
Philips 42PF9631D 42 in. Plasma Television Logo
545 people viewed this question
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
