Question about Xerox Phaser 6120/YN Laser Printer
XEROX PRINTER PROBLEM FUSER TEMP. - Xerox Phaser 6120/YN Laser Printer
Posted by tally_dhn on
Tareq Bin Mostaq Mostaq
    President:
  • Xerox Master
  • 1,449 Answers
Problem on fuser unite.When it hole surface block waste toner then arise this problem.Clean all surface and wast toner then solve your problem.
Posted on Jan 10, 2010
Multifunction /Copier/Scanner Laser Printer Printer Error Fuser Temp. in xerox 3100mfp
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Then replace broken part.
Sep 15, 2010 | Xerox Phaser 3100MFP/S Laser Printer
SISODIYA COMPUTERS "I AM SOLVE THE PROBLEM FUSER TEMP ERROR "
BUTTON FAST PRESS STEP BY STEP
LET'S START
PREES- MENU BUTTON
* BUTTON(THIS IS STAR BUTTON)
# BUTTON
1 BUTTON
OK BUTTON
STOP BUTTON
MENU BUTTON
# BUTTON
^ BUTTON(THIS UP ARROW BUTTON)
OK BUTTON
YOU LAST BUTTON PRESS OK AND POWER "OFF" AND WAIT UNTIL 15 MINUTE AND PRINTER START PROMBLEM IS SOLVE FUSER TEMP
Mar 12, 2010 | Xerox Phaser 3100MFP/S Laser Printer
Printer error fuser temp
You will have to replace the fuser. Call 1-800-835-6100 and follow the prompts to purchase parts. It isnt real expensive. Just make sure you still don't have some warranty left on the parts.
Mar 09, 2010 | Xerox Phaser 3100MFP/S Laser Printer
PRINTER XEROX 3100MFPX FUSUR TEMP PROBLEM
Most likely you have had a fuser failure. It could possibly be the fuser and power supply board.
If the fuser rolls melted together, I would replace both, if you can remove the fuser and are able to rotate the gear, then just the fuser needs replaced.
Call 1-800-835-6100. They can take care of what you need.
Jan 05, 2010 | Xerox Phaser 3100MFP/S Laser Printer
I own a Xerox Phaser 3100MFP and it keeps giving me an error message saying "Printer error Fuser temp"...Help
please your xerox phaser is in fuser light is checked is not courently okthis parts is damaze? then changing the fuser temp and new added.
Sep 22, 2009 | Xerox Phaser 3100MFP/S Laser Printer
Xerox Phaser 3100 Printer Error Fuser Temp.
fuser Temp printer error problem.please give me the solution.
Sep 14, 2009 | Xerox Phaser 6120/YN Laser Printer
U4 error code - Xerox 5328 copier
U4-2 Low fuser temp problem U4-3 High fuser temp problem U4-4 High fuser temp problem U4-6 High fuser temp problem
replace thermistor in fuser unit
Oct 03, 2008 | Office Equipment & Supplies
Xerox Phaser 6120/YN Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Eric Engel
efs_perpends
efs_perpends
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
