Ok first unplug dryer on the side of the heating element housing you will see the high limit switch black plastic with a sticker and a metal nose pull the 2 wires off check for continuity with ohm meter should be closed if it reads closed put wires back. Now look for a white ceramic rectangle piece it is a thermal fuse pull the wires and chech continuity if it shows closed it also is good. if either of these show open they need replaced. Now if both showed closed unplug wires from heating element check continuity should read continuity. if open element is broken. Now assuming this all shows good. Then it could be the timer or the centrifical switch on end of motor.
