Question about Tylo SUPER SPORT-U8 Heater 8 kW
My heater overheated, it went past 200 degrees. I later found out my son took the thermostat off the back of the handle, and put it in a ice bucket....now my heater wont turn back on....is it broke??what should I do to troubleshoot it? I reset the breakers, and pushed a little white button on the left side..any suggestions would be great!
Posted by colin4martin on
Colin
    Genius:
  • 1,584 Answers
Probably cooked the circuit board as well.
Get son to buy replacement!!!
Posted on Jan 08, 2010
1994 buick ninety eight 3800
bad heater core won't cause engine to overheat unless its leaking coolant and coolant level low, if car is running hot make sure your radiator cooling fan is coming on, fan won;t come on unless a/c is on or engine reaches 228 degrees
Sep 03, 2012 | 1994 Toyota Land Cruiser
Refrigerator doesnt get cold
you have a defrost issue, could be a timer, a board, a heater, or a bimetal. i suggest you call for service. 200 to 350 depending
Jan 03, 2012 | Kenmore Side by Side Refrigerator
Yesturday i emptied the ice bin from all the ice and put it in the freezer. When i woke up today i went to get ice and there were only like a handful of cubes in the bin. I turned on the ice maker plus and...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Aug 06, 2011 | LG Refrigerators
Freezer cold fridge not found no air flow. took apart and found evap frosted up bad. checked heater with meter and it has continuity. do not want to just start replacing parts. Does it have a timer or...
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Mar 22, 2011 | Kenmore Washing Machines
There were no issues with overheating or heater before.i just changed water pump,tensioner pully and thermostat.filled with coolant now car overheats and heater will not work.it just blows cold air.let car...
Ok, first thing, its a Ford Product. Thats an issue for another time. But for this problem, perhaps you bought the wrong thermostat for the car. They are made to open at specific temperatures. If the one you put in opens at say 200 degrees, and your car wants one that opens at say 145 degrees, then your gonna over heat even before you have any water flowing through the engine to keep it cool.
Mar 03, 2011 | Lincoln Continental Cars & Trucks
I’ve have problems with getting sufficient heat from my 2002 Jeep Liberty - Took the 2002 Jeep to dealership - First they wanted to replace the thermostat [$200], I explained it was replaced in November...
Here's the way I usually approach problems such as this. First I'll hook up a scan tool that allows me to see the actual engine coolant temperature is [not just what the gauge says] as the vehicle is being driven down the road at highway speeds. The coolant should be near the 192 - 200 degree range to get the best heat out of the heater. If the coolant temp is below that level then the amount of heat you'll get will drop according. IF the coolant is reaching full temp but the air coming from the heater isn't very warm then you could have a restricted heater core or a temp control door in the ductwork that isn't working properly and is allowing cold air to sneak past the heater core. Usually if you have a water pump impeller problem you'll also have an overheating problem as the pump often isn't able to move enough water through the radiator to keep the engine cool. Hope this gives you a starting point and good luck!
Dec 22, 2010 | 2002 Jeep Liberty
Refrigerator shuts off for extended periods of time. The temp falls, ice melts, etc. then it comes back on, sometimes couple hours later , sometimes the next day.
DEFROST PROBLEM
Dec 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Hi i have a ge profile side by side. the digital temp inside the refrigerator side is reading frezzer 23 refrigerator 47. The frezzer wall is iced up. when i press against the frezzer wall the coil feels...
Sep 27, 2010 | GE Profile PSW26P Stainless Steel Side by...
Kenmore fridge and freezer not cooling
Check to see if there is any ice built up on the back wall of the freezer. If so thaw the ice and take the back wall out of the freezer. next check to see if the fan is running in the freezer (evaporator fan) This fan is what circulates the air from the freezer to the fridge. If it does run then you have a defrost problem (if ice is on the coils and back wall). Then replace defrost timer, heater, and thermostat.
Nov 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Tylo SUPER SPORT-U8  Heater 8 kW Logo
269 people viewed this question
Top Tylo Pool & Spa Experts
john h
David Spradling
David Spradling
rogerpaul3
Level 1 Expert
Are you a Tylo Pool and Spa Expert? Answer questions, earn points and help others
