Question about Lexmark JetPrinter Z55 InkJet
SOURCE: Lexmark Optra T612
The broken part is called the bell crank arm part number 56P1228 this is very common. If the printer isn't recognising your tray, remove it and check the little plastic fingers on the left side (half way down the tray) and the metal springs in the printer (left side) which the tray pushes on to.
Posted on Aug 04, 2008
SOURCE: X73 found loose spring
I was having a similar problem. After finding the service manual (4402_X73.pdf) and taking the thing apart, an ink-covered broken spring fell from the inside. I checked around the 'Maintenance Station' and found the other half still hanging. Apparently -because I haven't got a replacement yet to confirm- the spring goes across the bottom of the 'Maintenance Station' to a lever on the other side. If someone can tell me where to post a picture of the thing, I'll gladly do it.
Posted on Sep 17, 2008
SOURCE: prints roller smear marks
Laser printers do not use Ink. The problem is most likely a defect on the drum, which in this model printer, is part of the toner cartridge. Replace the black toner cartridge with a known good one and test.
Posted on Oct 04, 2008
SOURCE: I installed a maintenance kit (fuser, charge
Have you tried a different cartridge? Was there much spilled toner inside the printer? If you go into menus, and then help menu you can print a print defect guide that you can line up on your print and it will tell you exactly which part is causing the issue.
Posted on Mar 12, 2011
Nov 18, 2010 | Logitech 9311570403 Mouse
May 08, 2010 | Sony Handycam CCD-TRV128 Camcorder
Dec 26, 2009 | Sunbeam Food Mixers
May 16, 2009 | HP LaserJet 2430n Printer
Apr 07, 2009 | Venta VS 100 Humidifier
Oct 05, 2008 | HP LaserJet 3030 All-In-One Printer
Aug 25, 2008 | HP LaserJet 4L Printer
Sep 12, 2007 | Brother IntelliFax-2820 Laser Fax
Oct 16, 2019 | Lexmark Office Equipment & Supplies
24 people viewed this question
