Televison & Video Logo
Posted on Jan 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Green squiggly line distorting picture on TV
I have a Samsung hd5525w rear projection tv. It has a green squiggly line that is distorting the image of the tv. I want to know if this problem is fixable (without spending a fortune).
Chi Chu
Level 3:
  • Televison & ... Master 8,457 Answers
  • Posted on Jan 08, 2010
Chi Chu
Level 3:
Answers
8457
Questions
0
Helped
2822399
Points
26282
Ur Convergence is dead.Parts and labors,about $300 dollars.
THe picture is either yellowish green or yellowish orange. And has squiggly lines thru the picture. What needs replaced?
Tv have a problems known as a convergence problems,it dead.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead.Try website like Tvrepairworld.com to buy a whole rebuild convergence board for the replacement.The Samsung/Akai tvs using the same convergence board.
I have a green line in my picture. The picture is distorted some
Press the menu button on the tv if the tv still ahs the green line the tv needs repair. If there is no green line through the menu try a second source, a dvd player or a game system. If the issue only is with the original source, replace the original source.
I have a HCN4727w samsung. Red/green shadowing. Bowed image
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Red, Green convergence lines are wavy
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
*Screen Looks 3-D
*Colors wont align
Samsung HCN4727W Rear Projection TV, green screen, audio works
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
1helpful
Picture suddenly distorted, green and violet lines
It is convergence out ICs failure problem and you need to replace two ICs in convergence board/ section in TV.
If you are not familiar with TV repair then call qualified TV tech to fix it.
The screen image is distorted with flashing green lines across the entire screen. If I unplug the TV and then plug it back it the normal screen returns temporarily
hi ive got a samsung SP24Q2HL rear projetion tv
it appers not to recive signal and only has distorted screen with green lines it sometimes works but very unreliable
please help
thanks luke
Samsung parts for convergance problem
http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Samsung rear projection 42" green curves causing distortion just started
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
