Question about Acer Aspire AS5520-5537 Notebook
New Aspire with windows 7 is very slow
I got a new computer for christmas. I noticed that it was slow installing games and opening programs. My old windows 08 is lightning fast compared to this. It was fast running the programs though. But when i got itunes i tried to import songs from a cd and it took 10 minutes for one song. I also noticed that in the task manager it says cpu usage is 100 while doing nothing. I compared this to a windows XP computer and noticed the CPU usage was usually at zero but would spike up to arround 30. Is this a problem with the computer or is windows 7 just slow??
Posted by Cam on
  • Cam
    Cam Jan 08, 2010
    I disabled some of the start up programs and that seemed to help a little bit.
Faisal Khan
    Prodigy:
    An expert who has answered 500 questions.
  • 674 Answers
Run System In Safe Mode: To identify the root cause of theproblem, first of all restart your system, press and hold F8 key. Do thefollowing once you are on the desktop. 1. Right click on Computer.
2. Select Manage.
3. Click on Event Viewer in computer management.
4. Double click on Application.
5. Check for the errors.
6. Similarly double click on System and check for the errors.
7. Search for the solution to this problem. Now you are able to easily diagnosewhy Windows laptop starts up very slow. b> Limit your Startup list: A long list of programs in startupcan adversely affect the performance of your PC. There are some programsrunning in the background without knowledge of user that causes Windows laptopto start slower. To solve the problem, follow the steps given below. 1. Click on Start button.
2. Type "msconfig" in search option.
3. Double click on the file.
4. Click on Startup.
5. Uncheck all unwanted programs.
6. Close system configuration utility.
7. You are done. b> Uninstall unwanted program: Sometimes Windows laptop starts upvery slow due to unwanted programs hogging your memory. To fix this problem,below are some steps. 1. Click on Start button on thetaskbar.
2. Go to Control Panel.
3. Double click on Add or Remove Programs.
4. In the list of programs, select the program that you no longer needed.
5. Click on Remove button.
6. Repeat step 4 for all unwanted programs.
7. You are done. b> Scan System for Viruses: Windows laptop may start slower due to any virus onyour computer. To solve this problem you should scan your system with somepowerful antivirus program. b> Run Disk Clean Up: Running disk clean up utility isalso helpful to resolve slow Windows start up. To run disk clean up utility,here are the steps given: 1. Click on Start button.
2. Go to All Programs.
3. Click on Accessories.
4. Now click on System tools.
5. Click on Disk clean up. b> Defrag hard disk: 1. Click on Start button.
2. Go to Command Prompt.
3. Type "chkdsk" and press Enter. b> Defrag Registry: You mayuse some safe program such as McAfee secured RegInOut to fix registry relatedissues.
Posted on Jul 05, 2011
Edward
    New Friend:
  • 104 Answers
It may have a virus or just a bad windows install.
Try using your restore disk or option to bring back to factory.
Posted on Jan 08, 2010
  •  Edward
    Edward Jan 08, 2010
    Yes, removing start up programs can help, but if this is a new machine then the problem is not running programs. Your machine should be very fast out of the box. It is not unheard of to have a new install of Windows that just isn't running right. go and restore the machine with your restore disks. If it still doesn't run fast do it again. If that doesn't work bring it back and try another one while in the store if it is slow also get your money back.
  •  Edward
    Edward Jan 10, 2010
    Don't forget to rate my solution!
Acer aspire 5745G I7 running extremely slow even after reloading the operating system?? Where is "speed step" in BIOS?
My first concern with this would be the hard drive. In my experience, if an OS has been re-installed and the speed issues remain then this is the most common problem. If you have another 2.5" hard drive then try swapping it and installing a new OS on this. If it works then you have your problem.
Oct 20, 2013 | Acer Aspire 5600 Series 5630-6951 Laptop
Tip
Computer faster guide
Computer slow is really a headache to users. Therefore, people always ask question about how to get a slow comouter faster. For that, you must firstly know why computer slowdown. After diagnosing the problem, you can fix slow computer more easy.
Here we gives you some advice to make your PC faster.
The most possible causes of slow problem for an old computer.
1 Corrupt registry is the number one cause. In short, the registry is the fort of the system. The most important date and setting are restored in the registry. External change may damage the key and make it mess up. In that case, you may face a blocked Windows. Visit here to cleanup registry and speed computer.
2 Discontinuous harddisk is know as the NO.2 reason. I would not talk about too much. Here just show you how to defrag a slow computer.
  1. Open My Computer.
  2. Right-click the local disk volume that you want to defragment, and then click Properties.
  3. On the Tools tab, click Defragment Now.
  4. Click Defragment.
3 What you should notice is that old computer may lack of RAM. The machine configuration never keep up with the computer development. Now the basic requirement is 1 GB.
Why a brand new computer is slow?
1 I think you forget to update the anti-virus. When merchant install system for your, they also install antivirus program for you. However, the anti-virus is not updated to latest virus database.
2 Sometimes, it is Windows fault. You have to update SP2 to SP3. Suggest you download all microsoft patches.
on Aug 19, 2010 | Computers & Internet
Tip
Game slowing down at random times
  • Many users while playing a game on there computer seem to notice that it slows down at random times throughout game-play, This common on most computer as users seem to forget about other applications running on there computer.
  • If your CPU is not fast enough and you are running many applications while your game is running you will notice the game isn't responding as fast as it should, The best way to solve this is disable all programs which you are not using including MSN messenger and any browser or File sharing/Torrent Application.
  • Also make sure your anti-virus is configured not to scan automatically otherwise it may start scanning while you are in game and cause dramatic lag, Most anti-virus's will provide an gamers profile which you can activate to prevent certain anti-virus features while you are playing your game.
on Aug 01, 2010 | Computers & Internet
My pc is very slow. if i will open my pc sometimes it will hang up....is it possible that i will reformat my pc?what OS should i install? can i install windows 7?
It's slow because it has been corrupted by a virus. So yes, you must reinstall it.
Yes, you can put Win7 on it, but if you're using the pc just for home use, no gaming , no special programs, it will be better to install a Linux on it - not only it's free but it's practically impossible to infect or hack.
Try this one
http://www.mandriva.com/en/downloads/one/
Jul 07, 2011 | Biostar G31-M7 TE Motherboard
I am running windows 7 and trying to play Monopoly new edition by infogrames. it installs fine but then crashes when you launch the game.
Its an old game for windows 7...
You are best bet:
  1. Right Click on the shortcut icon
  2. Select Properties
  3. Click tntcy_0.png button
  4. Find MONOPOLY.EXE
  5. Right Click
  6. Select Properties
  7. Select Compatibility Tab
  8. Check Run this program in compatibility mode for:
  9. Select Windows XP (Service Pack 3) for start and try going down the list from there.tntcy_1.png
  10. Apply and try running the game again
May 22, 2011 | Infogrames Monopoly 3 for Windows
My old computer with a Borland dBase 5.0 program on it crashed but the hard drive was salvaged and I have hooked it up to my new computer. However, my old computer ran Windows XP on 32 bit, the new one...
Do I need Windows XP Mode?
Windows 7 has several built-in tools to help with program compatibility and Windows XP programs should be installed directly on Windows 7. Windows XP Mode runs many older Windows XP productivity programs and that are not natively compatible with Windows 7, thus helping realize cost savings and reduce possible operational downtime by extending the life of existing software. Visit the Windows 7 Compatibility Center to find software that works with Windows 7.
http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
It's the best of both worlds: The new Windows XP Mode lets you run older Windows XP business software right on your Windows 7 desktop.
Designed primarily with small- and medium-sized businesses in mind, Windows XP Mode comes as a separate download and works only with Windows 7 Professional, Ultimate, and Enterprise. Windows XP Mode also requires virtualization software such as Windows Virtual PC. Both are available free on the Microsoft website.
Download
Learn how
Jan 23, 2011 | Borland DBASE 5.0 Upgrade Version Academic...
My new PCCD-ROM F.R.O.G. game will not install on my new Dell desktop computer. Can you help me?
Is the game listed as "for Windows XP" or "for Windows Vista" or "for Windows 7" ?
Is your new Dell desktop running Windows 7?
Are you using the "Program Compatibility Wizard" to install an XP/Vista application
into your Windows 7 system?
Jan 18, 2011 | Computers & Internet
Hello, my name is Annette Hayes, I purchased a 3D Frog Frenzy CD many years ago. Over the years I have been able to install it on new Pc. I just recently purchased another PC and when I tried to install...
See, all programs and games grow old, and computer operating systems change as well.
What i would advice you to do, is to ask the repair man to install Windows XP on a Virtual Computer inside your computer. And install the game there.
Jan 02, 2011 | Cosmi 3D Frog Frenzy for Windows
Acer Aspire AS5520-5537 Notebook Logo
1,403 people viewed this question
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
Michael Thomas
Michael Thomas
