Question about Buck Honda Odyssey 2004 Car Stereo/radio Wire/wiring Harness
I want to install am/fm cd cassette player into my honda odyssey lx model,by removing the casste player ,harness connectors are same
Posted by damodar_airf on
Bellok
    New Friend:
I have a hyundai matrix 2014 and I would like to replace the radio but I can't find the wiring diagram so I can connect the right wirings
Posted on May 29, 2014
Wilson Martinez
  • 171 Answers
No the wiring harness are not the same, if your factory radio is standar audio system this is the part # Metra 70-1721
Posted on Jan 08, 2010
Will the pioneer deh p3100ub fit a 92 civic?
Yes, it should slip right in, but I recommend you buy the adapter for the wiring harness. Look here for details and instructions are pasted below:
http://www.crutchfield.com/p_130DEH1700/Pioneer-DEH-1700.html?tp=5684
1992-95 Models
See Figure 4
Removing the radio will require removal of the front part of the center console.
The original equipment radio has a coded theft protection circuit. Before beginning removal, be sure to know the code for re-installation. The code is erased whenever the battery is disconnected or the No. 32 (7.5A) fuse from the under hood fuse/relay box is removed. When power is re-connected, the word "CODE" will be displayed and will require entry of the 5-digit code for that particular unit.
WARNING All SRS wire harnesses are covered with a yellow insulation. Read the SRS precautions found in this section and install the short connectors as described.
  1. Disable the SRS system as described in this section.
  2. Remove the center instrument panel by removing the four philips screws on the top and sides.
  3. Disconnect the 4-pin connector from the cigarette lighter.
  4. Remove the two screws, then disconnect the 16-pin connector and the antenna lead.
  5. Carefully pull the radio/cassette player out.
To Install:
  1. Plug in the 16 pin connector and install the two retaining screws.
  2. Plug in the antenna lead, the cigarette lighter and carefully install the unit.
  3. Install the center instrument panel. Re-connect power to the car, and enter the 5-digit theft protection code for the radio/cassette player.
  4. Enable the SRS system.
Aug 14, 2011 | Pioneer DEH-1700 CD Player
Instructions on replacing engine wiring harness on 05 lx honda accord 4 cyl
1) unplug connectors
2) remove harness
3) install new harness
4) connect harness.
Really...what instructions do you need specifically. Way too vague to give you any help.
May 09, 2011 | Honda Accord Cars & Trucks
I purchased a 1997 Honda accord Se for my 16 year old daughter but the radio/cassette doesn't work. I want to put in a cd player without paying a fortune, what is my best option?
i would recommend purchase an aftermarket cd player. you can also purchase a cd player is dash kit. that will come with the wire harness connector and the brackets to hold it in place.
Dec 10, 2009 | 1997 Honda Accord
HOW TO INSTALL FM MODULATOR ON HONDA ODYSSEY 2003 EXL
You simply need power, ground, and remote turn on (switched) - these can be obtained 9tapped into) from the back of the radio.
RADIO 12V white/blue
RADIO GROUND black
RADIO SWITCHED white/red
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 02, 2009 | Pyle FM Modulator For Mobile DVD's - PLMD2
Replacing tape player with cd player
you will need the replacement harness for your model year which is available at pep boys auto or advance auto
Nov 28, 2008 | 1999 Honda Accord
2005 Honda Odyssey - Replacing CD Player
I've been looking for instructions to remove the stereo in my 2005 Odyssey as well. I found these instructions that should help: http://www.collegehillshonda.com/instructions/gen3_odyssey/musiclink.pdf It is actually for adding something else to the stereo, but there are instructions for removing the stereo there. You can easily find a kit that allows you to mount a standard car stereo in the space. You might also check out http://www.crutchfield.com Any stereo bought there comes with the necessary mounting kit and harness for your vehicle, as well as vehicle-specific installation instructions.
Sep 30, 2008 | 1996 Honda Odyssey
How to remove the cd player from Honda odyssey EX 2002 model
The trim panel that surrounds the radio and contains the climate controls and possibly 1 or 2 other switches needs to be removed. Apply gentle, even pressure on the edges and gradually move to the other edges, and the clips should pop out.
I would advise against unplugging the climate controls or radio however other switches can be unplugged safely.
Once the panel with the climate controls is removed there should be 4 phillips head screws holding the radio in place; remove those and you should be golden.
Feb 19, 2008 | Car Audio & Video
Buck Honda Odyssey 2004 Car Stereo/radio Wire/wiring Harness Logo
409 people viewed this question
Top Buck Car Audio & Video Experts
Marvin
Marvin
 Mikey
Mikey
Are you a Buck Car Audio and Video Expert? Answer questions, earn points and help others
