Question about Uniden Cordless Phone
I have a uniden Dect 6015.calls go straight to voicemail
I have a uniden Dect 6015. Sudenly everything has started going straight to voicemail - the phone does not ring at all. I have looked at owners manual and can find no instructions on how to change it.
Posted by jennyhard18 on
4 Related Answers
Anonymous
  • 31 Answers
SOURCE: Calls go straight to voicemail
Your phone is fowarded to Voice Mail and do not disturb is on. Turn DND button off. If it is not the case on your phone press intercom # key 601 then hang up. Then do intercom #key 604, dial your voice mail extension numbe, r press the speed dial Select button, dial 16, press the redial button then hang up.
Posted on Dec 28, 2008
Anonymous
  • 37 Answers
SOURCE: Disconnects incoming calls after one ring
The problem may be a short on your line. (Have the local Teleco check your line.) If you have other phones, you may want to check them for dial tone(DT) when this happens. If you have no DT, your cordless may be the problem...unplug, and let charge overnight. If problem continues, replace the battery in cordless, or discontinue use.
Posted on Apr 29, 2009
Anonymous
  • 85 Answers
SOURCE: phone does not ring goes straight to voicemail
hello, its is possible that you have activated your call DIVERT...
Try to deactive all call DIVERT on your phone device.. Go to your settings, check CALLS SETTINGS, THEN YOU CLICK ON CANCELL ALL DIVERT..
cheers.
Posted on May 15, 2010
Anonymous
SOURCE: Panasonic DECT 6.0 always says "New Voicemail"
Try pressing and holding the MUTE (CLEAR) button until the handset beeps. Then clear all incoming calls.
Posted on Dec 01, 2010
The Base says new cid:34. How do I get it back where it was. I tried to get a number that rang and it changed the settings
Julie,
Sounds like 34 is the # of calls that came in on the caller ID (CID) lis
To open the Caller ID list, press the little phone handset symbol (it looks like a big "C" then ID next to it) on the right side of the 4-way button (it toggles 4 ways, so press to the right side to get the Caller ID list).
The phone will show the number of new calls (or Caller ID records) and the total number of stored CID records. Use the "up" arrow and "down" arrow to scroll through the list.
It looks like you have the Uniden DECT 6.0 6035, so I attached the manual in case it helps.
You can set up the answering machine if the voicemail was deactivated by Lifeline (page 38 in manual shows how to set up answering machine). If 4 rings is not enough, you can change the # of rings (page 40) and to use the answering machine/voicemail, see page 42 in manual.
Uniden 6035 1 Owner Manual
Nov 03, 2015 | Uniden DECT 6.0 Cordless Phone ID
My phone goes straight to voicemal, how do I fix this?
Call your provider, they can help you reset it. It appears you are not getting a ring signal. It is also possible it has been forwarded.
Jul 21, 2014 | Uniden Lands Phones
How to retrieve voicemail messages
Since you didn't specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
Nov 24, 2011 | Uniden DECT 6.0 Cordless Phone ID
How do i set up voicemail for a uniden dect6.0?
Since you declined to specify the model of your Uniden DECT 6.0 system, select it from the list beginning at
http://www.uniden.com/owners-manuals/dect-phones/scat/
to get the manual.
Aug 23, 2011 | Uniden DECT 6.0 Cordless Telephone...
HOW TO CLEAR VOICEMAIL
http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl/
Aug 12, 2011 | Uniden DECT 6.0 Cordless Telephone...
How can I get it to ring 7 times before going to voicemail?
Since you didn't specify the model of your Uniden DECT 6.0 system, select it from the list beginnng at
to download the manual.
You may have to settle for 6 or 8 instead of 7.
Aug 10, 2011 | Uniden DECT 6.0 Cordless Phone ID
How do i check my voicemails on my Uniden DECT 6.0
Since you didn't specify the model of your Uniden DECT 6.0 system, select it from the list beginning at
Jun 10, 2011 | Uniden DECT 6.0 Cordless Telephone...
I need help getting my phone off of silent mode. One of my kids put it on silent somehow and now I cannot get it to ring again.
I to am stuck in silent mode, voicemail won't work, the whole entire phone is jacked up, just because i had my phone number changed, are you kidding me?? Not ringing, not doing anything @ all, can someone tell me what to do? please thnx :)
Jun 02, 2011 | Uniden DECT 6.0 Cordless Telephone...
How do i change my voicemail greeting on uniden dect 6.0 base set with 2 additional cordless units.
Select the model of your phone from the list beginning at
to get the manual.
May 18, 2011 | Uniden DECT 6.0 Cordless Telephone...
Uniden Cordless Phone Logo
2,964 people viewed this question
Top Uniden Lands Phones Experts
k24674
Marvin
Marvin
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
