Question about KitchenAid Ovens
You are very lucky if that machine lasted as long as it has. if you replaced those hinges in 2007 that's 10 years. The last one i bought they said we will be lucky if we get five to ten years out of the new one. Unless you want to put money in this one its probably cheaper to buy a new one in the long run.
They could not care less if you tell them you won't buy anything from them again. I had a large company official tell me that.
Posted on Apr 21, 2017
SOURCE: Oven door hinge detached from the oven
Pull the door completely off and re-insert the door on the hinge supports.
Posted on May 23, 2009
SOURCE: my husband did not put a nail (or something) into
this is a serious pain
down a few hundred of these overe the years
ok you will need long needle nose pliers
and a sturdly flat head screw driver
try to reach it with the needle nose
and usae the flat head as a pincher try to work it behind the hinge
these springs are 110 lbs so it will take some effort to get them out
short of this you will need to drop them out of the cavity on each side of the drawer
Posted on Oct 08, 2009
SOURCE: thermador oven (c301u) door hinges weak, how to install new hinge
This is a relatively easy fix however you will need to remove the door and it is heavy!
Start by opening the door completely and engage the small "locks" that are at the base of the hinge. This will ensure that the spring loaded hinges do not "spring open" when you remove the door. You then will need to remove the hinges from the door via a series of phillips head screws that hold the hinge assembly in place. The new hinges must be "preloaded" into the Open position using a vise or some means of holding the hinge in place while you use a small section of pipe to provide leverage needed to open the hinge so that the Locks can be engaged.
Once the new hinges are "pre-loaded" and the locks are engaged, you can reverse the procedure to re-install the hinges into the door and re-install the door.
Good luck!!
The hinges are commercially avaialble from Applianceparts.com
Posted on Oct 13, 2009
SOURCE: Brand new whirlpool built-in oven.This is a 24
This problem is solved...tech ordered a new pair of hinges.Thanks
Posted on Oct 25, 2009
SOURCE: I removed the oven door and took out the hinge to
You will have to pull the oven dorr up and out again, it might be a little hard to pull but the door didn't went in straight and it's preventing the hinge from closing. go to repairclinic.com for an ilustration on how the door and hinges fit in place.
Posted on Jan 14, 2010
