Maytag 24 in. MDB7600A Jetclean® II Built-in Dishwasher Logo
Anonymous Posted on Jan 07, 2010
Quietseries 300 : Fills OK, timer functions OK, no water movement
Quietseries 300 : Fills OK, timer functions OK, but - won't spin (throw water about)
  • Anonymous Jan 07, 2010
    This is a dishwasher that fills but will not spin
    Quietseries 300 : Fills OK, timer functions OK, but - won't spin (throw water about) This is a dishwasher; does the door latch have a sensor?
Anonymous
Level 2:
  • Expert 262 Answers
  • Posted on Jan 07, 2010
Anonymous
Expert
Level 2:
Answers
262
Questions
Helped
75204
Points
802
Check the Lid switch. Most top load machines will not spin unless the lid is down and this is determined by the lid switch.
  • Anonymous Jan 10, 2010
    yes the door has usualy one or two switches.
Washing machine won't wash I.e. bowl won't turn in wash cycle or spin. Fills with water ok. Will drain if start button is reset. Rear panel removed, drive belt in tact.
pull shafe out it is likly broken to find out between timer and shaft look to see if timer move by itself and if it does sorry u have broken shaft
How to move around brandt wm 550
see this causes and fix it. God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
1helpful
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
Dishwasher will not advance beyond water fill stage
when it fills and water stops /the motor will start up in a min.or so. you should be able to hear the motor & water or just a hum then the motor will click and quit .. the seak kit came with a tool to center the pump housing properly / if this was done it should work. unplug motor and run thru cycle if it finishes cycle timer ok and pump is still problem . the motor may have been damaged from the first problem and water got in top brg. ck motor see if it will turn ...mm
Nov 22, 2009 • Dishwashers
1helpful
Kenmore 90 Series Washer - No Agitator Movement
You need a timer the motor contacts are probably burnt.
3helpful
Washer won;t drain or start spinning
check the lid switch if its ok
you have a problem with the timer
replace it
5helpful
2answers
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
1helpful
Agitator does not move but activates high pitch buzz
genaral electric washing machine fills won,t spin but throws out water as if it did, goes to next cycle same thing, but sounds as if it is spinning but isn,t, hose not clocgged i checked, what else can be the problem,sounds ok but not spinning
Machine fills with water & then clicks but goes no further. It will drain but no other function seems to work
That is probably a problem with the timer.
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Not finding what you are looking for?
    Top Maytag Dishwashers Experts
    Mike Cairns
    Mike Cairns
    Paul Bade
    Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
