Question about EliteGroup NFORCE 570 SLIT-A Motherboard
Can not boot from cd rom...bios boot order is set
Can not boot from dvd rom...bios boot order is set correctly. On the boot screen. Boot from CD is displayed for both drives but instantly moves on to boot from hard drive.
  • Anonymous Jan 21, 2010
    I finally did get the computer to boot from cd. In the bios, I had to set ALL boot devices to CD. When Windows install rebooted the computer, I set the order back correctly. It has worked fine ever since....
John Daly
Set all in Boot priorty to CDROM
Set Other Boot Device to No.
Posted on Dec 26, 2012
JWConrad
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 37 Answers
Your cd-rom either is missing the driver or is non-functioning
Posted on Jul 27, 2015
Anonymous
    New Friend:
Set your boot priority like this
1.DVD/cdrom 1
2.hard drive
3.network
thats works
Posted on Jan 21, 2010
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
How can i boot my dell studio from cdrom so i can reinsall from external drive?
Turn on the machine, press F12 once the Dell splash screen is displayed, the boot menu will show up. From the Boot Menu, use up-down arrow keys on the keyboard and highlight the CD/DVD/CD-RW and press Enter.You will see another menu, select "Boot from Cd-Rom" and press enter to select it. The system will boot up from the CD-Rom. Please note that this settings is only for one time boot, once the system is restarted, the boot sequence will be restored to the previous saved settings. If you wish to set it from the Bios, enter the Bios settings by hitting F2 or Delete (should be shown at the bottom of the Dell splash screen) while you see the Dell Splash Screen. In the Bios settings menu, go to Boot options and make the changes with the boot sequence.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
May 21, 2011 | Computers & Internet
I have sata dvd writer.when i connect it my computer does not boot.does intel D102ggc2 supports sata dvd writer?
You're Intel motherboard does support up to 4 SATA hard disk drives including SATA CD-ROM / DVD-ROM drive, reader/writers. This MB also includes two serial ATA IDE ports.
The most likely reason you're system is not booting is because all SATA ports are all seen as Master drives. By connecting the SATA DVD-ROM drive the bios auto configured the SATA ports.
You'll need to enter the bios when you're system boots-up. Press the F2 key on you're keyboard right after hearing a single beep. You will than enter the bios main menu. Listed at the main menu are devices connect to the motherboard. (Instruction on how to move around in the bios is listed at the bottom of the screen). Mainly, the hard disk drive or (drives) and the SATA DVD writer. You'll need to open the Boot tab. Look for boot order. You want the boot order set like so;
First boot device: [Floppy disk] drive; if one is connected.
Second Boot device: [Primary Hard Disk] drive.
(The drive with windows installed on it). (This drive may be ATA IDE or SATA; you did not provide that information).
Third Boot device: [DVD-Rom] drive. Save and exit the bios. The system will auto restart.
You're windows operating system should load correctly after the auto re-start.
The SATA data cable and the SATA power cable should be checked for good connection. It only takes a little bump to make either loose.
Here is the link to Intel for you're motherboard;
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22+D102GGC2+%22
Mike
May 12, 2010 | Intel D102GGC2 Motherboard
Emachine T4060 -black screen-no cd-rom boot
If it is DVD Drive, then sometimes in BIOS you'll also find the option for DVD Drive together with CD Drive. Choose the correct one and boot your PC.
Please come back and vote for me, if this turns to be helpful for you. Thnx
Mar 27, 2010 | E-Machines T4060 PC Desktop
Was installing hp starter disk 6500 into dell4550 dell was terned off my mistake and now wont re-boot just blank screen with small light flashing were fast upper left corner of screen
Enter the system bios and set the boot order to boot from CD ROM. If this order is correct and you are still experiencing the same issue. Re-enter the bios and set it to default setup. However, enter the boot order and ensure the CD-ROM is the first boot device and Hard Drive is the second.
Enjoy the power of a PC
Mar 13, 2010 | Dell Dimension 4550 PC Desktop
Will not use the cd rom drive as boot for repair
I suspect you have the boot order in the bios set up to boot off the hard-drive first. You need to change this so the computer will attempt to boot off the CD rom first before it attempts to boot from the hard-drive. I'll try to describe how to do this. While the computer is booting push whatever key it indicates you need to in order to enter setup. Often this is the F2 key. Use the arrows to move up or down the list to an entry that will say something like "boot order". Usually you can select this by hitting enter. Then follow the instructions on the screen to move CD rom to the top of the boot order list. This may involve using the page up and page down keys. Exit and save. This usually involves using the Esc key. Once you set this it will always check the CD rom for a disk before it tries to boot from the hard-drive. It will still boot like normal if it doesn't find a boot CD in the CD rom.
Jun 30, 2009 | Acer Aspire 3004WLCi Notebook
Want to Boot from dvd ROM
when the pc in post usually on dells bios there is a boot menu option it is usually f12
if you don't know what your doing in the bios it is not a good place to test your skills after pressing F12 just choose cd rom for boot
Jan 28, 2009 | Dell OptiPlex GX280 PC Desktop
I can't boot from external usb dvd/cd drive
please try to remove the connection between motherboard and vd/dvd drive.
then perform the previous steps.
Jan 27, 2009 | HP Compaq Evo Notebook N1020v PC Notebook
Toshiba a205 laptop wont boot
try to boot the windows from external DVD or CD ROM on USB if you have acces to your BIOS set the bios to boot from USB. i think your CD/DVD rom is not working properly, or is no booting from it bios is not setup corectly.
Jan 17, 2009 | Toshiba Computers & Internet
Problem ide
Hi gustabir,
try this first. (If I am understanding you correctly).
Power on the PC, press the Delete key every two seconds untill the boot menu loads. Go to the title, Boot. Set you're boot device's in the correct order. They should be listed as follows.
1st Boot device Floppy drive. (If a floppy drive is connected).
2nd Boot device CD-ROM/DVD drive.
3rd Boot device Hard drive.
(If you're CD-ROM drive is not listed in the bios main menu, than you're CD-ROM drive is not connected correctly). Please check the CD-ROM data cable is firmly & correctly connected), also check the power cable is firmly connected). If you are using more than one CD/DVD-ROM drive on the same data cable, check that you are listing the correct CD/DVD drive in the boot order. To change the drive's order while in the Boot menu, see page 34 in you're manual.
If the above does not address you're problem, please describe the issue/problem again.
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 27, 2008 | Foxconn (945G7MA-8KS2) Motherboard
EliteGroup NFORCE 570 SLIT-A Motherboard Logo
5,271 people viewed this question
Top EliteGroup Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
