I lost my manual and i am freezing...i need the fusebox diagram for a 1997 mercury mountaineer ppppleeeease
1. pwr antenna 7.5 amp 2. high mount stop lamp 7.5amp 3. lights 15 amp 4. left headlight 10 amps 5. data link connector 10 amps 6. airbag, blower motor relay 7.5 amps 7. lamp dimmer 7.5 amps 8. RH headlight, daytime running lts, fogs 10amps 9. autolamps, memory seat 10amps 10. blend door ( heater), shift lock actuator, cruise control, brake press limit, console, integrated contol panel, rear blower relay 7.5amp 11. radio, dimmer relay, inst cluster, autolamps 2 7.5 amp 12. liftgate wiper washer, front washer relay 10amps 13. brake on off switch 15 amps 14. antilock brakes 10amps 15. airbag diagnostic 7.5 amps 16. wiper main 30amps 17. cig lighter 25 amps 18. heater-a/c eatc module 15 amps 19. radio noise cap, ign coil, PCM power diode 25 amps 20. radio, powr ant 7.5 amps 21. turn /hazards 15 amps 22. turn hazards 10 amps 23. rear wiper relay, 10 amps 24. anti theft 10 amps 25. cluster 7.5 amps 26. rear window defrost, overdrive trans, backup lamps 10 amps 27. interior lighting 10 amps 28. GEM, mem seat 2 , 7.5 amp 29. radio CD changer 10amps 30. not used 31. rear blower relay, RH heated mirror, 7.5 amp 32. heated rear window switch RH heated mirror 7.5 amp 33. DRL module, RH LH daytime running lamp 15 amp 34. power antenna module, remote chassis unit 7.5 35. not used 36. not used
Try,
http://www.scribd.com/doc/9655335/1997-Mercury-Mountaineer-V8Power-Distribution-Box
Testimonial: "thank yall so much for responding to my question so quickly...u rock"
Fues for the Moon/Sun Roof
