Question about Sanyo Heating & Cooling
I have a split system SAP-K181AHA, SAP-K241AHA that is leaking water from unit inside house.
Posted by saggers on
jdthefixer
  • 746 Answers
Air conditioners wring moisture from the surrounding air that collects in a pan under the cooling coil in the inside unit.
Chances are that the condensate drain is plugged or the drain pan is plugged. Look for a hose that exits the inside unit and runs to a drain. You can follow it back to the drain pan of the A/C unit. If there is water sitting in the pan, then either the hose or pan or both are plugged.
Turn the unit off, get a small bucket and remove the drain tube. Catch the water in the bucket. Blow through the drain line until it's clear. If the thought of doing this is too repulsive, then use an air compressor or even a manual tire pump. Now check the drain pan in the unit for debris and remove as much as possible from the pan and the drain fitting.
Both the pan and drain line should be checked at the beginning of each cooling season.
Reinstall the drain tube and see how it works!
Posted on Jan 08, 2010
I have a Daikin mini split system. It is leaking water from the inside unit inside my house. Why?
Dirty? Check your filters, shine a light inside to see blower wheel. Drain plugged? Wetvac on the drain outside.
Otherwise it's a cracked drain pan, bad fitting, drain is trapped multiple times, possible it's low on refrigerant.
Jul 20, 2017 | Heating & Cooling
Why does my split ac unit leak inside the house?
This happens when the drain pipe is too high, or kinked. The pipe must be lower then the drain pan in order for the water to drain. This is a common problem.
Jul 27, 2014 | Sanyo Heating & Cooling
Just asking how many amps existing Sanyo SAP-K181AHA would be connected to in Australia. Need to replace it, is 4.5Kw cooling and same price to replace with 7Kw but unsure if 30amp already in place
The 4Kw constant speed Ac will draw about 7.6 amps @240vac while the 7Kw Ac unit will draw around 13.8 amps @ 240vac. This is normal running. extreme conditions will be slightly more no doubt. The figures are approximate.egardsCol R.digital controls.com.au
Mar 05, 2011 | Heating & Cooling
Hello, I have a split system air conditioner (one of SAP-K181AA or SAP-K241AA or SAP-K251AA) and it is dripping cold water inside onto the floor. Can you help.
try to unclog drain line of your ac.or check the elevation of you indoor may be the drain water cannot flow smothly.
Jan 30, 2011 | Sanyo Heating & Cooling
Leaks water inside
Water leak is the common problem in split air conditioners.. It happens due to:
1. Air filter block 2. Evaporator coil Block. 3. Less rpm of blower motor. 4. Drain line blocked.
To rectify, service the unit completely. If blower motor less rpm, replace motor capacitor.
Dec 18, 2010 | Sanyo Split System Air Conditioner
Hi, i have kelvinator split system in my house.but...
Sounds like a clogged drain pan. You will need to have the unit professionally cleaned.
Hope this helps I take the time to answer your question so please rate me
May 19, 2010 | GE Zoneline AZ38H12DAD Split System Air...
Fujitsu split system air con leaking inside the house from the unit
The drain pipe must be plugged up or bent. Lift cover of unit and look for water in the tray, find drain hole and remove obstruccion inserting a piece of wire. Be gentle and careful. After the water in the tray drains out, pour a glass of water in the tray to rinse it out and make sure the drain pipe is completely clear.
While you are at it, clean the air filter of the unit.
Good Luck
Mar 07, 2010 | Electronics - Others
Samsung split systim leaks water from inside unite
when ambient air goes across your evaporater it causes it to condense check your drain hose it may be clogged up not allowing the water to drain properly
Feb 06, 2010 | LG LSC121PMA Split System Air Conditioner
Leaking water from inside samsung split sytem
if your indoor unit is leaking water down the wall,it is from one of two things.First, is possibly the insulkation on the copper lines is coming loose and the suction line is condesated,with no way to drain,it drips down the unit.The other possiblity is that the drain hose is coming loose from vibration and leaking a little.
Dec 31, 2008 | Heating & Cooling
Air Conditioner leaking water
there is a drain that comes out the wall to the outside find it and **** it out with a good wet dry shop vac.
Oct 19, 2008 | Sanyo 09KHS51 Ductless Mini Split Air...
Heating & Cooling Logo
577 people viewed this question
Top Sanyo Heating & Cooling Experts
Dennis Boxerman
Harrie
Andrew Taylor
Andrew Taylor
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
