Car Audio & Video Logo
Posted on Jan 07, 2010
How do i fix my subwoofer?
Its an mtx sub that was given to me by my uncle, but it has a crack in (not sure what its called) the part between the cone and the case.
he said i might be able to fix it with silicone but i would like to get expert advice. on what i need to do to it, and if silicone is the best way.
Anonymous
Level 1:
  • Contributor 21 Answers
  • Posted on Jan 16, 2010
Anonymous
Contributor
Level 1:
Answers
21
Questions
Helped
3883
Points
27
My mtx ts5510 stopped working while driving. Was hooked to an mtx thunder 81000 class d and its still working. ????
Inspect speaker for loose wires/broken wires. Check inside box for loose connection. Blown fuse on amp. Ive literally pulled the wires out of the speaker. The little mesh ones from the terminal to the cone. Look for that. If you do find something broken or bad. remember you can call MTX and fix for a flat rate on most evrything they carry. Ive sent several amps there. normally around $100
How big of hole do i need for the mtx 6000 thunder 10in
The MTX Thunder 6000 T61544A is a 15" Subwoofer meaning you will need a 15" hole to fit the subwoofer into. The mounting plate that surrounds the subwoofer will extend past 15" allowing you to screw the sub in properly. Be sure to use a box that is at least 12 inches deep (sub is 10 inches deep by specifications + 2 inches for good air cushion behind.
1helpful
How do i wire a 8 ohm kicker comp 10" sub inside the box? and what is the best way to get more bump with a 600 w mtx amp and kicker comp 10" sub?
Ok, for an 8 Ohm sub, it is advisable to get another 8 Ohm sub. wire them in parallel down to a 4 Ohm load. You would wire both + wires together, and both - wires together to yield a 4 Ohm load at the amp. Majority of the amplifiers on the market are designed to give more power at a lower impedence, or Ohm load. You just have to make sure that your amp will take a 4 Ohm load. Without knowing the model of the MTX amp, I can't give more advise. However, this should be able to give you and idea of where to start. The main problem is that you have a single 8 Ohm sub in the Kicker Comp.
My mtx 10' sub is jammed, is there anyway i can fix it by myself without costing a fortune, i believe its a burnt coil
The voice coil has overheated. If you feel confident, you might be able to purchase a re-cone kit and do it yourself. But it's an art, so to speak. Contact the manufacturer, or a speaker re-coning service.
2answers
Sub with stuck cone
It's stuffed! We used to take a 9 volt battery and just scratch the terminals to try and un freeze it. If that doesn't work, then ship it.
My friend sold me his subs today and one sub doesn't work. they're mtx thunder 8000 will mtx fix the sub for me?
They probally would, but i just found that sub for 51.00 im sure it would cost that and more to have.it fixed
14helpful
Sub stopped working, unless i push on it?
sounds like maybe the wiring from the cone to the magnet is ripped or broken.... which is why when you push the cone in it works because it pushes it far enough to make the wires touch just barely, but when you let it go the wires seperate and you get no sound.
Your wire is built with slack, so when the cone goes in and out during a song, the wire can move with it and not get broken. but when you cone moves too in or too far out, then that wire can snap or become disconnected.
I have fixed this by soldering the copper wire, but you may lose some power because your copper wire might be a bit shorter(it will probly break again)... or you can lengthen it, but it is not easy to solder... some places will fix it for you but the cost may be more than what it is worth.
This is just a guess, take your speaker outta the box, and look to see if these wires are broken, lose, or frayed.
good luck.
Rotten foam rubbers
You can have "The Speaker Factory" re cone them. Call for an est.first Generally gonna be less expensive to replace.
12'' sub woofer
cone is cracked if you see the crack sometimes epoxy or rubber glue can wrok but Id ship it back to audiobahn if under warranty otherwise buy another one as shipping and repair gets expensive
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
