Question about Icom IC-R10 Handheld Scanner
ICOM IC-28H very low sound from radio even thought volume is max
I have an ICOM IC-28H vhf transciever and do not get any increase in volume when I turn the volume control, both on internal as well as external speakers. Do I need to clean the contacts on the volume control, if so how do I do it.Thanks emeskew
Posted by sqaisar on
  • Jack Patrick
    Jack Patrick Oct 04, 2018
    I have a icom ic-28h now with power supply antenna and coax cable and orginal owners manual I'm looking to sell if your interested give me a shout
Jeff Robertson
I had a very similar problem on a hand held scanner. In my case the mylar speaker cone had separated from the voice coil. I found an exact replacement for under $4 at Allied Electronics.
Posted on Feb 16, 2010
Anonymous
    New Friend:
  • 10 Answers
This is not a fix for the faint of heart. remember that you have a Transceiver, not just a Receiver. There is more that can go wrong once you have opened it up. With that being said, if you still want to tackle this, you need to gain access to the volume control pot with the knob off and spray contact cleaner into the pot itself. Use a Qtip with cleaner on it to clean the exterior contacts. Make sure all is dry before re assembling. If that does not work, then your volume pot is going bad and needs to be replaced. Best place for parts is www.amateurelectronics.com
Posted on Jan 25, 2010
I need amounting brack for my icom ic m302 vhf marine transceive where can i get it
Try Ebay as a source. I have had good luck finding such accessories for reasonable.
Aug 20, 2014 | Icom IC-M302 VHF Marine Radio
How to repair Icom IC-M700 HF transeiver?
Does it have an external speaker plugged in the back? If so try unplugging it see if the internal speaker works, if it doesnt have an external speaker plugged in try one, maybe the internal speaker went bad from moisture.
May 28, 2014 | Icom M700 Pro - IC AT-130 automatice tuner
Ic m505 not receiving
turn the squelch down? the RF gain down too
do you have an attenuator turned on ?
Apr 01, 2014 | Icom IC-M505 - VHF/DSC Marine Transciever
I have an ICOM IC M505 marine VHF which is the closest model to the one described below. It is less than 3 years old. The channels have been very quiet including channel 16. This prompted me to test the...
Probably not the squelch but the speaker on the VHF. These radios are famous for crapping out when getting wet.
Try listening to the weather radio VHF ch 01, 02, or 03. depending on your location and play with squelch.. Keep in mind they do make external speakers you can hook up.
Jul 24, 2017 | Icom IC M504 Black Submersible PLUS Marine...
I would lke to know the reference code on the audio out put ic, used in the VHF MARINE IC-M302.
Quick description as per ICOM Manuals:
Quote
The AF amplifier circuit amplifies the detected signals to drive a speaker. The AF circuit includes an AF mute circuit for the squelch. AF signals from IC1 (pin 9) are applied to the de-emphasis circuit (R61, C89). The de-emphasis circuit is an integrated circuit with frequency characteristic of –6 dB/octave. The integrated signals pass through the high-pass filter (Q5, R62–R67, C90, C91) to suppress unwanted lower noise signals. The filtered signals are applied to the AF mute circuit (IC7B), and then passes through the [VOLUME] control (VR board; R1) via the “VOL1” signal. The signals are applied to the AF power amplifier (IC6, pin 1). The output signal from IC6 (pin4) drives the internal (external) speaker.
Unquote
I thus assume the IC you are looking for is the IC described as IC 6.
Data sheet availible online: http://www.datasheetcatalog.org/datasheet/sanyo/ds_pdf_e/LA4425A.pdf
The IC is a Sanyo LA4425A. A 5W Power amplifier.
Apr 02, 2010 | Icom IC-M302 VHF Marine Radio
Can someone provide a wiring diagram for the
hello, my name is paul and wondering if you can help me with a wiring diagram of cool talk throat mic icom earpiece, hope to hear from you soon .
kind regards
paul
Dec 05, 2009 | ICOM Informatique IC-A23 VHF NAV/COM Air...
I need the IC-F11/S to talk to my CP100 (vhf) model
Programming the CP100:
http://www.thekidshuttle.com/ABC%20Docs/CP100_Manual.pdf
Programming the IC-F11:
I believe one must purchase software and a programming cable to program the frequencies of this radio.
Mar 13, 2009 | ICOM Informatique Icom IC-F11 5W 16ch VHF...
Ut 40 and 50 tone squelch
Go to http://www.repeater-builder.com/icom/icom-ic-4ga-gat-ge-svc-man.pdf , there is a layout of the decoder in this pdf file. I hope this helps
73's de Patrick N5SLI
Nov 14, 2008 | Radio Communications
Icom IC-R10 Handheld Scanner Logo
1,477 people viewed this question
Top Icom Radio Communications Experts
Robert McClure
Vincent G
Vincent G
Ngoro
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
