Macally IceCam Personal Web Camera Logo
Question about Macally IceCam Personal Web Camera
Hi there i am trying to use a mcalla icecam on an old 12 inch silver mac book with usb 1 port. I downloaded the drivers and plugged in the camera and it just brings up coloured lines on the screen, plus when i click on webcam monitor icon on the screen it comes up with an incomplete dialogue type book. how do i get the camera working?
Posted by ingridleary on
Rochell Cruz
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 143 Answers
Did you happen to get a cd with thyat icecam? if so, then you need to uninstall it, unplug it from your mac book. and using the cd driver, run the installation again and plug it back into your mac book. another thing that you might want to do is to run up manually for your mac book. sometimes the drivers for the usb ports need to be updated.
Posted on Jan 07, 2010
I would like to download the info on an old extermal hard drive. when plugging the iomega into my mac book pro - it says that USB devices disabled due to to much power to re-enable USB devices ... this...
Some older external hard drives required special USB cables with two plug-ins. This was not for the sake of data transfer, but because they needed more power than a single USB port could provide. Some older units even went so far as to have the laptop-type "brick" power supply since they needed so much power. This is probably what is wrong here. Your Mac Book probably doesn't have the current to handle the drive on the port and is protecting itself. Some units have one or two high-power USB ports. This may work if you have one. Otherwise, you'll need to download the drive another way.
1helpful
I use to just plug in my nikon coolpix L610 to my computer ,now it wont work.Whats going on?
hi,
did you try to plug it into another port than the defective one?
sometimes windows loose the control of one port and by changing it recognizes again on new port....
you may also have hardware drivers problems, take a look at the hardware properties to see if there is not a small yellow triangle on some hardware, it can be the source of the problem, search for updated drivers and restart.
or go to nikon's site, search for last driver for your model, and install it, this must solve the problem...
cheers,
mich
I plugged my FujiA303 usb into my new MAC Book Pro
do you have a sound cards in your camera where you can take out the card and put it into a computer. try this buy a card reader and put the card into the reader and hook it up to the mac, (which I have ) and maybe they will show up. you have a program on the mac called i photo and thats how i do my pics, but if it doesnt show then yes u prob lost them but try this. it may work good luck.
Icecam serial number rubbed off and i need software!
  1. Normal 0 Be sure the camera is plugged into the USB port before running the program.
    As you run the program, write down the info about the camera so you will know what you have .
    Double click on this site and download the Camera Diagnostic Tool and run it to check out your camera and/or problem.
    http://www.download32.com/webcam-diagnostics-d35065.html
    I ran the diagnostic on my camera to give you an idea how well it works.
    Give it a try.
    Hope this helps. Bud
1helpful
2answers
I can't install the Icecam because of Finder applications
Are you running OSX 10.4? Not supported yet...
  • Mac OS 9.2, Mac OS 10.2, Mac OS 10.3
  • Elsewise call MacAlly support or Apple.
    1helpful
    How to install an icecam 2 in a Mac G4 with 1.1 USB port
    Drivers can be found here: http://www.macally.com/EN/Techsupport/Drivers.asp
    If you want to use the camera with iChat you will need the third party software called iUSBcam found here: http://www.ecamm.com/mac/iusbcam/
    Side note, I have yet to get this camera to work in OSX 10.3.9, so tread lightly.
    Mac doesn't notice 2wire Pc-port
    as far as i know, 2wire stopped supporting PC-Ports. But this might help you out. I checked the 2wire website and they still might have a driver for ur PC port. Here's the link:
    http://support.2wire.com/index.php?page=download
    try that a go and see if it works. Keep me posted.
    Ice Cam will not work
    1. Please make sure you install the software first before you plug the iceCam.
    2. You may try it on another built-in USB port
    3. If still not working, the iceCam may defective.
    1helpful
    2answers
    IceCam on Mac OS 10.4.8
    I have a mac book with a & web can not been seen in system preferences
    Top Macally Computers & Internet Experts
    Paul Bade
    Mike
    Muzahura Frank
    Are you a Macally Computer and Internet Expert? Answer questions, earn points and help others
