Question about Lucent Legend MLX-28D Corded Phone
How do I change the name display on the MLX-28D?
Posted by meganelhaj on
george peters
    President:
  • Lucent Master
  • 860 Answers
A label can have a maximum of seven characters.
To administer Labels for Extensions from the System Programming console:
  1. Press Menu.
  2. Press System Program.
  3. Press Exit or Start.
  4. Press More or Right Arrow Key.
  5. Press Labeling.
  6. Press Directory.
  7. Press Extension.
  8. Dial the extension number that you want to administer.
  9. Press Enter.
  10. Press Drop.
  11. Enter the label information for the extension number selected.
  12. Press Enter.
  13. Press Exit or Back.
  14. Press Home or Exit to exit programming mode.
Note: When programming on the system programming console, use the buttons next to the display to specify the letters A through I and punctuation. Use the line/feature buttons to specify additional alphanumeric characters for labels. Use the template provided with the System Programming console to see which line buttons correspond to which alphanumeric characters,
Posted on Jan 07, 2010
1 Related Answer
Anonymous
  • 201 Answers
SOURCE: MLX-28D Corded Phone Change Time
The time is stored on the phone system, not the phone. You first need to know which phone system you have. This phone will work on a few different Avaya phone systems (AT&T and Lucent are now Avaya)
You can find all the manuals for free at www.avaya.com but you first need to know which system you have.
Posted on Jan 28, 2008
Number of Rings Before Call Goes To Voicemail
From the system programming menu either in the pc programming tool or from the console phone enter into system programming, options,more, group coverage delay. set here from 1 ring to 9. Good luck.
If this was helpful please send me a rating.
Thanks Dan
Jul 29, 2009 | Lucent Legend MLX-28D Corded Phone
Programing Ayava partner - 18d Phone
This will need to be done at Extension 10 or 11.
Press Feature 00
Press LEFT intercom, LEFT intercom
Press right intercom. Display will ask for an extension number.
Enter the extension number you want to modify.
Now it should say "program ExtXX"
Press * * (STAR STAR)
then touch the lines in the order you want to pick them up, when finished entering the order....
PRESS * * (STAR STAR)
Then Press Feature 00 to exit programming.
Apr 30, 2009 | Avaya Corded Phone avaparp18d
How do I recall a deleted message Merlin Legend MLX-20L Phone?
I assume you are also using a Merlin Voice Mail? Once the message has been deleted there is not way to retrieve it.
Mar 09, 2009 | Lucent Merlin Legend MLX-20L Phone
Need to change extension names on a MLX-20l phone
http://dstech1.com/changing-the-name-on-an-extension/
  1. Press Menu.
  5. Press Labeling.
  6. Press Directory.
  7. Press Extension.
  9. Press Enter.
  10. Press Drop.
  12. Press Enter.
Jan 13, 2009 | Lucent Merlin Legend MLX-10D Phone
Change time
I assume you got this fixed? But, Euro style is a Partner phone, and Merlin is a merlin...contradictory terms.
Aug 11, 2008 | Lucent Legend MLX-28D Corded Phone
Caller i.d.
You can not log caller ID information on the Legend phone system
Apr 29, 2008 | Lucent Legend MLX-28D Corded Phone
Nov 06, 2007 | Lucent Legend MLX-28D Corded Phone
Console Problem
When you switch phones the system does not know this. All programming is stored in the system, not the phones. If you swap phones of the same model nothing should change. If you put a phone in with different button configurations then things very well may change.
It's not an easy fix. The phone system would need to be re-programmed for that phone port.
Sep 27, 2007 | Lucent Legend MLX-28D Corded Phone
Console Lights
You can do a self test by pressing buttons in this order: Intercom, speaker, *, 0, 0 The phone will make noise and all the lights will flash. If all the lights are working in self test but no in normal operation, then it's probably a programming issue. Have you had any other problems or mysterious changes in the system? Possibly after a power outage or lightning storm??
Jun 06, 2007 | Lucent Legend MLX-28D Corded Phone
Lucent Legend MLX-28D Corded Phone Logo
408 people viewed this question
Top Lucent Lands Phones Experts
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
