The dishwasher is not cleaning food off at ALL! It appears to be the bottom sprayer. I cannot see any food blocking it. How do I get the bottom sprayer apart to trouble shoot? thanks, Norma
Hi
Disassemble the lower spray arm and check the status of the water delivery hole. Lastly, check the spray tower, which consists of several rotating parts. Make sure no objects are stuck in the spray tower, then close up the dishwasher and try using it.
Remove the raised screen to the right at the sump to clean that out. The screen in the sump can get clogged up. Check the fourth diagram, part number 506 which I am talking about.
http://www.partselect.com/MultiModels.aspx?ModelNum=gld5860&searchTerm=&RefineSearch=0
That is the parts breakdown you may have to pull the unit out to get to the sump .
It's easier to get to all the parts that can cause the problem .The real problem is the food still on the dishes when you wash .So once cleaned out don't add plates or bowls that have food still on them.it's the only way to stop that problem.
Check the 11th diagram for part number 329, it is flapper valve and it can be stuck by food particles.Try the heavy duty cleaner CLR pour a few cups in and let it go through a cycle.
Please check this link for more information:-
http://www.ehow.com/how_4852098_poor-cleaning-of-dishes-dishwasher.html
