I just got the Gigaware 2 port usb powered vga splitter and I have ywo monitors connected. Both monitors show the same thing but I want to extend the desktop across both screens, however Windows XP does nto show that there is 2 monitors connected.
Posted by pqmaloney on
IQUIT
  • 3,940 Answers
A display splitter will only mirror the screens, you cannot extend the desktop via a splitter.
Most portables cannot support dual monitors without a docking station.
Posted on Jan 07, 2010
Rinoo Kumari
  • 2,973 Answers
You are using a VGA splitter. That means whatever is coming to it is being sent to two (monitors). Hence both display similar data.
To extend the desktop to the other one you have to attach the second monitor to the VGA (15 pin) port on the laptop, if there is one. You can find out if you can by right clicking on the desktop and selecting Properties->Settings. If there are two monitors made, you can. If there is only one monitor mad, then NO. And you must also have a 15 pin VGA port on the outside of the laptop.
Trying to set up 3 monitors in windows 7. using on board dvi to connect to one monitor and on board vga to connect to switch box (which then splits video signal to two vga monitors). can only get the dvi...
Sometimes it is difficult to answer a question without asking very basic questions. Using a DVI and a VGA ports will allow you to have screens with different things showing on them. If you use a splitter, the two monitors connected to the splitter will show the same thing on both screens. Is this what you want? I use a splitter at church to have Powerpoint on the main computer monitor, the program then shows on the screen on the wall and the TV monitor, as well as the second monitor at the computer. My splitter occasionally acts up, and I found that unplugging it and plugging it back in makes it work for another couple months. But a splitter for only two monitors is very cheap, no switch box involved.
Oct 01, 2017 | StarTech.com VideoView ST124 (65030772815)...
Using the splitter i can not get windows 7 to recognize the other monitor and enable multiple monitors
Hello there,
As you've said you're using a display splitter, the result will be identical screen on both monitors. splitters main function is to split VGA signals into N of outputs. where N=number of outputs. no matter how many monitors you attach to your splitter, the windows only recognize monitors attached directly to your video card. Windows requires a video card that has two or more output VGA or DVI outputs to get second extended monitor or display link device.
If you're video card has two outputs follow the instruction below.
1. plug the VGA or DVI other cable on the unused port. 2. power on the second monitor. 3. right click on the desktop, click screen resolution.
4. click the display in gray, Multiple Displays: it depends on the user.
5. I selected extended display. 6. apply and ok.
This spreads your desktop over both monitors and lets you drag items between the two screens. This is how most people use two monitors, and it's the default setting for desktop computers. you can use your mouse to grab the title bar (the top portion) of a window and drag it to your new display.
Hopefully this information is helpful. Thank you for using FixYa..
Jul 17, 2011 | Computers & Internet
We are trying to set up a dual monitor system so that we cn watch movies via the pc [not laptop] we have plugged in all the cables but still zilch
if you want to set up a dual tv monitor system using via pc as a source you will need a VGA splitter usually 2 or more output. now how are you going to connect the 2 monitor and PC to the VGA splitter. first make sure your tv monitor is supported by service input for PC unit. then prepare the accessories needed. the VGA splitter and VGA cable. vinceisaac_30.jpg vinceisaac_31.jpg sample image for VGA splitter VGA cable or connector how are you going to hook up the splitter and VGA cable to the tv monitor and PC
  • you need 3 vga connector and 1 splitter to connect a dual monitor system.
  • connect one end of the vga connector to the pc unit and the other end to the input port of splitter.
  • now the 2 remaining vga connector connect to the output of splitter either of the port, then the 2 end wire you must connect to the input port ( pc service port ) of the 2 tv monitor. make sure you set up the right input either with the remote or at the tv unit to recognized the pc source.
  • you almost done the connections now at this point plug the tv monitors, plug the dc adapter supply of the vga splitter and lastly turn on the pc unit to view movies. i hope it will help you just ask me if you have further questions thanks for choosing the fixya.
Jun 05, 2011 | Televison & Video
I have a video splitter and I'm not getting anything on my monitors. The splitter says active and the monitor appears to recognise the splitter but doesn't show any images. Is there something...
an extended desktop
click start control panel display change display settings adjust resolution this may vary depending on your operating system you should a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes
hope this helps
May 08, 2011 | GrandTec GVC-1000 (gvc1000) VGA Video...
I have 2 identical Dell monitors on vga splitter plugged into port on laptop running Win 7. The NVIDIA control panel will only recognize the 2 Dell monitors as 1 display + 1 laptop display. How can I set...
you will have to change the settings in the control panel to an extended desktop once you have this lead connected click start control panel display change display settings you should a no 1 and a no 2 with detect and identify keep an eye on the television screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended tesktop always click apply after making any changes
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! red x right click select reinstall drivers hope this helps
http://majorgeeks.com/SiS_UniVGA5_Graphics_Driver_For_Windows_7_d6264.html
Apr 11, 2011 | Impact Acoustics 2-Port DVI-D VGA Splitter...
I have bought a vga splitter to split one vga port in to 2. the other monitor isn't being registerd by th comuter when i use the splitter
The computer will only see either one monitor or the splitter itself as the monitor, it won't recognize them separately or be able to put different data onto each (if indeed it is a true "splitter")
It's like the output from a satellite receiver. Just because you put a cable splitter on it so that you can have 2 TV's hooked up, both will be on whatever single output is coming out of the receiver, it doesn't let you watch 2 different shows, one on each screen. You'd need another receiver for that.
Likewise, if you want to see 2 monitors on the computer, there has to be 2 separate video outputs (some cards provide more than 1 output, but since you got a splitter, I am assuming this isn't the case for you).
Mar 12, 2011 | Computers & Internet
I have a new macbook pro and want to use a diamond bvumd3 to have 3 independent displays. my external monitors are both Dell 2310 with 1920 x 1080 capability. I have the bvumd3 connected into my macbook...
You would have to purchase separate BVUMD3 devices in order to get multiple extended monitors. Since each BVUMD3 has one DVI port with a USB hub, the DVI port is the only port available that allows video. Using a VGA splitter will not work with our device since each DVI port is allowed to carry only one video signal through to the monitor. You could purchase separate BVU195 devices if you do not need to use the USB hub on the BVUMD3.
Dec 27, 2010 | Diamond Multimedia Diamond BVUMD3 USB...
Is it possible to connect 2 external monitors to a dell xps m1330?
Yes, it is possible you can connect 2 or 2 billion external monitors, all you need is the extension cable, which is normally called a spilter or usb to vga spilter, and you can connect as amany as you want.
remember, USB to VGA adapter. or spilter.
else
There's plenty of evidence to indicate that using two screens is more effective than one; at least up to a certain point. There's also a strong indication that those two monitors need to be the same size, since your visual receptors seem to get confused by screens of different sizes. A recent Utah study indicates that using 2 20-inch monitors allowed people to complete tasks 44% faster than using 1 18-inch monitor, making a pair of 20-inch screens from Dell for under $600 sound like a steal. Since many people I know have switched to using a laptop as their primary machine no matter where they are, the trick of using two monitors (at least when docked) can be crucial.
The trick I use for connecting 2 external monitors to my own laptop is to connect one to the external video port on my laptop and a second monitor gets connected to a DisplayLink adapter. The adapter connects via USB allowing you to extend your desktop to another screen. They are sold under a variety of brand names which makes the adapters a little tricky to track down, but a quick search of eBay for USB to DVI Adapter turns up several options that are basically the same thing under several different names. DisplayLink also links to several online stores, although they do a lousy job of labeling which country each store serves.
a654cc6.tif
Oct 13, 2009 | Dell XPS M1330 Notebook
Cant extend workspace
The splitter you bought allows you to split one video signal into two. For example, a teacher using a computer to teach a class. She has one computer, one monitor she can see and then the splitter allows the students to see what she sees. To display independent screens you'll need to add another card to your system. Microsoft Help and Support lays out how to do this with Win 2000. No splitter involved.
Apr 10, 2009 | Computers & Internet
Dual monitors can't extend desktop
Connecting Two Monitors
Use the cable adapter to connect a VGA monitor and a DVI monitor to the DVI-I connector on the back panel.
When you connect two monitors, the video driver will detect this connection and activate the multimonitor functionality.
This is the only way to enable extended display. If you use a standard splitter and connect two DVI montors, the display will only be mirrored.
Detailed documentation is available at http://support.dell.com/support/edocs/systems/op755/en/UG/HTML/ultrasma.htm
Hope this helps! Please rate your feedback!
Mar 02, 2009 | Dell Optiplex 755 Ultra Small Form Factor...
Computers & Internet Logo
5,643 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
