GoVideo DV2150 DVD Player/VCR Logo
Posted on Jan 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
SAfe mode is stuck on. Was using DVD player
SAfe mode is stuck on. Was using DVD player normally this aafternoon. Have tried pressing power on both DVD and remote. Absolutely no response at all. HQ make.
Anonymous
Level 3:
  • Master 1,768 Answers
  • Posted on Jan 06, 2010
Anonymous
Master
Level 3:
Answers
1768
Questions
0
Helped
528681
Points
5915
1. Check the batteries in the remote to see if they have a charge.
2. If you have a DVD button on the unit itself press this and see if you get a response.
3. Unplug the unit and wait 30 second plug it back into the AC and try your DVD player , this usually resets the digital switch in the controller to default.
4. You may need to have the unit serviced.
5. Go to the manufacturer's site and check the "troubleshooting" information for this problem there may be a solution that I may not have covered here or there may be a procedure they have to reset the unit.
I hope this helps! Have a great New Year!
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
tip
Digilogic DVDVCR2 Safe Mode Unlock
Digilogic DVDVCR2 Unlock Safe Mode
Is your Digilogic DVDVCR2 stuck in SAFE mode?
Is is locked and unresponsive?
To unlock your Digilogic DVDVCR2, simply press and hold the red power button on the remote for at least five seconds. Sometimes it takes longer, so you may have to hold it up to 30 seconds to make your player usable again.
I hope that helps.
__________________________________
Would you like to unlock your Digilogic DVDVCR2 in another way?
Read my other Digilogic tip to make it a region free / multiregion dvd player.
on Apr 07, 2010 • Televison & Video
Android problems
Press and hold your power button and select to power your phone off. After it's completely off, about 1-2 minutes, press and hold the power button again to turn it on. After a few minutes it should have started up normally (without safe mode). Let me know how you go.
I do I get DVD/VCR off of the safe mode? DV2140
a samsung dvd shows the word safe. How do I return to the normal mode
1helpful
2answers
Fix"safe"
Turn the unit on, then press and hold the INFO button on your remote, the unit should go back to normal mode.
4helpful
Stuck in Safe mode
PRESS INFO BUTTON ON REMOTE FOR 5 SEC AND EVERYTHING WILL BE BACK 2 NORMAL
28helpful
5answers
Stuck in "safe" mode
Hold down power on vcr/dvd unit or the remote for 8 seconds. It turns the SAFE mode on or off.
6answers
Magnavox DVD/VCR player stuck in progressive scan mode
Right, mine was stuck for a couple of weeks and i tried lots of different things. What worked for me was plugging it out and in again. Press the power switch and then just before the tv switches from normal mode to dvd recorder press the eject button. However, I pressed it a few time so not exactly sure which one worked.
The burned DVD is now in a thousand pieces at the bottom of my bin!
Good Luck!
3helpful
3answers
Insignia DVD Player
Try hitting the "Lock" button on the remote. That solved the problem for us.
Top GoVideo Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
