This is a very hazardous condition. DO NOT stick you hand inside the unit as you may well get yourself burnd by microwave radiation. It appears that there is either a problem in your control panel assy or that you have time on your timer and the unit has a defective door switch allowing the magnetron to keep running with the door open. There are at least 3 protective micro-switches in the door closed and latched circuit. Very slowly depress your door open button or pull the door open slowly (depending on unit type) and listen for 3 distinct switch clicks. All 3 click should happen in less than one one half inch of the door opening. Try is sevral times and listen for the 3 clicks repeatedly. If you do not hear 3 clciks then you have a bad micro-switch If you hear all 3 clicks, more than likely your controll panel has a failed relay on it.
