Question about Logitech Z-2300 2.1 Computer Speaker System (3-Piece)
My desk top speaker is crackly and it is under the one year warranty. Where can I take it to replace it. Logitech Z-2300
Posted by annemosqueda on
Anonymous
  • 255 Answers
This is a stab at this problem because I would have to hear what kind of crackly it has. If the crackly happens while twisting volume knobs or tone knobs, and stops crackling (or even crackles SOME) after you stop twisting them, the potentiometers will need nothing more than to be squirted with some WD-40, Not the ideal stuff, but I have found it works better for this than anything else I've tried. Just spray the back of them with a little, but make sure none hits the speaker paper. (You'll have to crack open the case by unscrewing the screws.) If you don't have anyone handy to do this, some computer repair places just might help you out. Woops - I re-read.. you're still under the warranty? Then don't do any of this, and go to the Logitech website. They have a customer service department.
Posted on Jan 06, 2010
My one speaker sounds scratchy and doesn't have as good sound quality as it did when I first bought the system about a year ago. there is a 2 year warranty, will Logitech replace the speaker?
Hi, Thanks for using fixya.
Logitech Is a very good company and I am sure they would.
1-800-231-7717. Monday - Friday, 6:00am - 6:00pm PST ...
Terry
Feb 17, 2011 | Logitech Z-2300 Computer Speakers
Just got the speakers and am wondering what is the best way to position the speakers..Small speakers on each side of monitor and where should I place the woofer? I can put it on the same level (large desk...
Woofer usually right in front of you on floor between legs sort of, the other two, should go about shoulder height, about 1.5 - 2M apart. You sit in the middle, slightly angled inwards this gives realistic results.
Mar 27, 2010 | Logitech Z-2300 Computer Speakers
One of my desk top speakers is crackly like it is blown and it is still under the 1 year warranty
Hi there bud , 1st thing you want too do , when speakers are showing signs of trouble, take it into shop and ask them too fix it , Luckily you have your warranty ...Dont let it carry on without taking it in...Hope you come right Bud
Happy new year
Jan 06, 2010 | Logitech Z-2300 2.1 Computer Speaker...
My logitech z-2300 speakers are working but there is no base its like the basebox has died
Hi have you tried adjusting the bass on the Subwoofer , and/or The Eqauliser on your PC....
Hope this helps bud
Happy new year
Jan 03, 2010 | Logitech Z-2300 Computer Speakers
My left speaker doesn't sound but when I press the movable part of it this sounds again. Can be fix it?
Hi there bud,Theres a lose wire thats not correctly placed in , In this case , you would have too take it back to shop and inform them,, do not open it ,otherwise your warranty will expire...Hope you come right bud :D
Happy new year
Dec 26, 2009 | Logitech Z-2300 Computer Speakers
Where can I get repair for Logitech Z2300 speaker system? The yellow input to the amp doesn't work - both speakers will work in the other input
Contact Logitech - their information is here:
http://www.logitech.com/index.cfm/support_downloads/support_contactus/&cl=us,en
If it's under warranty, they'll likely be able to replace it.
Dec 11, 2009 | Logitech Z-2300 Computer Speakers
I have no sound from one of the speakers on my Z-2300 . The speaker itself isn't the problem. I swithced the wires on the back of he sub woofer and both speakers worked when I plugged them into the left...
probably not, seems the output ic or transisters are blown in the right channel. take it to a service shop. also see if under warranty, if you bought it new within the past year. it will be fixed or replaced..good luck...
Nov 13, 2009 | Logitech Z-5500 Computer Speakers
My logitech z 2300 subwoofer is not producing sound
Since this set is hardwired together and the other speakers are working, the only easy fix would be the subwoofer got turned down on the remote volume control. Anything more would mean its broken. If its under warranty take it back. If its not and you know somebody capable, you might have them check for the obvious,bad solder connections on speaker, or and open voice coil on the speaker it self.
Aug 26, 2009 | Logitech Z-2300 Computer Speakers
I need a replacement for my logitech z-2300 speaker wired remote control. How and where can I get one?
To the two people with problems. This sounds a bit odd, but do you still have the broken remotes? I'm looking for a broken one. I'd pay shipping and throw a few bucks your way if you could send it to me.
AIM: gonzoleben
Email: andywitzz [at] gmail [dot] com
Thanks!
-Andrew
Apr 14, 2009 | Logitech Z-2300 Computer Speakers
Logitech Z-2300 2.1 Computer Speaker System (3-Piece) Logo
Top Logitech Audio Players & Recorders Experts
Vernon Taylor
Lawrence Oravetz
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
