Question about Linksys Wireless-G Broadband Router
Linksys Routers lose setup
I have a Linksys router connected to cable. My father-in-law has a Linksys router connected to DSL. We live two houses apart. Different ISPs, but both of our routers have lost complete setup configs 2 or 3 times (at different times - never at the same time). Firewalls are turned on. Have to completely reset the entire config each time. Sometimes router won't accept passwords even though they're correct. Could someone be hacking in or is this random that it's happening to both of us? Don't even know where to begin. Not that tech savvy.
Posted by cafemocha on
Sergio Shamshoian
    New Friend:
  • 102 Answers
I Had to replace a Linksys for a client because every time was a power outages the router was losing the setup. So try unpluging the power supply.
Posted on Jan 06, 2010
How do you connect 2 routers into one network? I have a Linksys E3000 and a WRT110...I've had the wrt110 for over a year but I found I needed a second router to cover my entire house so I purchased a...
The easiest way is to run a long Ethernet cable from one of the 'LAN' (or 'network') ports on the "first" router to the 'WAN' (or 'Internet') port on the second router. The "first" router is the one connected to your cable-modem or DSL-modem. Both routers will auto-configure themselves for this "wired" connection. Configure the wireless-adapter in the second router as per normal.
Or, run a long Ethernet cable from the cable-modem (or DSL-modem) to a location in the "center" of your home, where you can put your wireless-router, such that its signal spans the entire building.
Or, move the cable-modem (or DSL-modem) to a location in the "center" of your home, and connect the one router at that location.
Dec 15, 2010 | Linksys E3000 Wireless Router
Switched from DSL modem to Cable modem. Linksys
If you had your linksys router controlling the DSL connection, it was most likely a PPPoe connection requiring a username and password. Most cable companies have dynamic IP address and do not require a username or password.
Open your internet browser, IE, Firefox etc and go to 192.168.1.1 >
Enter your router username and password, typically admin and admin
In the setup tab, change your connection FROM whatever is listed there and make sure it is Autumatic DHCP Save your settings, and restart the router.
You should be fine.
Oct 27, 2009 | Linksys Wireless-G WRT54GS Router...
Lose internet connection (hughes net) when hooking up router
I would contact your hughes net, that is a satelite provider. That is a total different system, than dsl or cable. Hughes net should be able to walk you through the setup.
Oct 26, 2009 | Linksys WRT160N Wireless Router
I went from a ATT dsl modem to a net gear modem and i cannot get the net ger mode and linksys mode to talk to the computer
Most DSL providers use PPPoE (Point-to-Point Protocol over Ethernet) to establish Internet connections for end-users. To set up a Linksys router, you need to enable PPPoE on the router’s web-based setup page.
To setup a Linksys router with a DSL connection you need to perform four steps:
  1. Verifying Internet Connection
  2. Connecting the Devices Together
  3. Checking the LEDs
  4. Setting-up a DSL ISP on a Linksys Router
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If not, contact your Internet Service Provider.
Aug 01, 2009 | Linksys Wireless-G Broadband Router
Computer repair tech said Linskey wireless caused internet prob
If you are using DSL as your internet connection there is a timeout period that could be setup in the linksys.
In order to change this you need to log into your router and on check on the setup page. You see the timeout option.
Check with your linksys manual for detailed instructions for logging into the unit. If you dont have it, you can always get it from their website.
Jul 31, 2009 | Linksys Wireless-G Broadband Router
Lose connection when hang up phone
Check to make sure that you have a DSL filter at every connection to a regular phone in the house.. Sometimes overlooked is a DSL filter for the connection to your home alarm system as well!
Jul 30, 2009 | Linksys Wireless-G WRT54G Router
DSL line disconnects on WRT54GS only
Try to change the LAN IP address of your router to 192.168.2.1 by accessing the router's Setup page. You also need to set your Westell modem to "full-bridge mode". You need to ask assistance from your ISP to bridge the modem. After that, set-up the Linksys router to PPPoE then power cycle it.
Apr 15, 2009 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G Broadband Router Logo
107 people viewed this question
Top Linksys Computers & Internet Experts
Mike
k24674
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
