Assuming it is windows XP here are the steps to fix that error: To complete part one, follow these steps:
Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer. Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line:md tmp copy c:\windows\system32\config\system c:\windows\tmp\system.bak copy c:\windows\system32\config\software c:\windows\tmp\software.bak copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak copy c:\windows\system32\config\security c:\windows\tmp\security.bak copy c:\windows\system32\config\default c:\windows\tmp\default.bak
Resolution: Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms: "A disk read error occurred" "NTLDR is missing" "NTLDR is compressed"
Cause: Corrupt boot sector
Resolution: Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms: "BOOT.INI is missing or corrupt" "Boot device inaccessible" "Windows could not start because the following file is missing or corrupt: <Windows root>\system32\hal.dll"
Cause: BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution: Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms: "Windows could not start not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause: Corrupt/missing system hive
Resolution: 1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot. 2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG 3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG 4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms: "Windows could not start because of a computer disk hardware configuration problem. Could not read from the selected boot disk, Check boot path and disk hardware."
Cause: Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution: Check the boot volume is accessible
Symptoms: Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause: System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution: Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
To repair missing or corrupted system file/s, boot up with the Windows installation CD then - Press R to repair when instructed. Press 1 or Enter to repair the C:\Windows folder. Then type chkdsk /r and then press Enter. The repair process will take quite a long time.
Type exit to quit Recovery Console.
Your computer will restart.
Note This procedure assumes that Windows XP is installed to the
C:\Windows folder. Make sure to change C:\Windows to the appropriate
windows_folder if it is a different
location.
If you need more help come back.Post /
thumbs / testimonial arewelcome!
Windows could not start because the following file is missing or corrupt: /WINDOWS/SYSTEM32/CONFIG/SYSTEM You can attempt to repair this file by starting Windows Setup using the original Setup CD-ROM Select “r” at the first screen to repair
So then i click r at the first screen and nothing happens...It keeps on repeating to repair on and on with the same message after i clicked r. I can't even access to the window...what can i do???
it is nothing but windows registry error. do one thing in another pc download the Hiren's boot cd from internet, write that file in a cd, try to boot from that cd & repair the registry. otherwise just format the operating system & reload the OS.
this problem occurs when you try to update drivers in the computer..sometimes windows XP cannot update the driver and that corrupts system.ini file as it has a lot of bad entries..Due to this you will get this error mesage..No its not due to virus.its due to an attempt to change system.ini file
Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM
That means the System Registry Hive has become corrupted.
There are two ways to get back up and running. The easy way which doesn't always work, and then there is the hard way.
Easy Way --- Note that this doesn't always work. When you are booting your system, press the F8 key during the start of the bootup sequence, meaning after it does the Power On Self Test.
Once you press the F8 key, you will be taken to a Menu. Select "Boot Using Last Known Good Configuration".
It will now attempt to load Windows XP using a past set of configuration files.
If that doesn't work, there is the next step....the hard way.
Hard Way Boot your system with the Windows XP Install CD, let the system boot into the Setup. Once in the Setup, choose to run the Recovery Console.
You will now be presented with a screen similar to good old DOS.
First, we will recover the System Hive.
Now, type in the following commands with pressing Enter after each line.
