Question about Sony PlayStation 2 Slimline Console
My PS2 has stopped working!!!
My PS2 has stopped working!! My sister was playing a game on my PS2, I walked in the room to see if it was going good, and noticed the game was still on the same loading page. I reset the system, but it just took me to the menu you get when there is no disk. I have tried several games, it seems like the spinner isn't even spinning. Can someone please help!?
Ben Wabnick
  • Sony Master
  • 2,404 Answers
Spindle motor went bad it sounds like. Open up the ps2 and inside of there, you'll see a ribbon for the drive, take it off of the board and then reseat it.
Now put the top back on and try the drive again. If it still doesn't spin then the drive will need to be replaced.
Posted on Jan 06, 2010
I have a play station 2 and I like to play Crash Bandicoot 2.Gortex strikes back,but the memory card won't work is this because it is a play station 2 memory card. thank you John.
First, check to see if your memory card has any room on it by turning on your PS2 while there is no game in the machine. Select your memory card, and see how many blocks are left on it, then see how many blocks are required to save Crash Bandicoot 2 games (should tell you on the game's box).
If there isn't enough room, delete some saves to make room.
If there is room, or you cannot view the saved data on your memory card then try putting it in the other slot. If putting it in the other slot does not fix the problem then your card is either damaged or the data is corrupted. In either case, you will simply need to use a different memory card.
Mar 11, 2011 | Sony PlayStation 2 (PS2) Console
Won't play ps2 games
take the Ps2 gaming console to nearest Sony service center the problem is with lens it sometimes run quiet well but sometimes got hang you can do one little thing & try it take any of the Ps2 games which are getting freeze while playing take Colgate toothpaste the regular one take a little bit of it & apply on the game disc rub it on the disc & then clean & wipe out with a clean smooth cloth & clean properly after cleaning the disc will look good neat in condition but please make sure no particle is left after cleaning & now play the disc on Ps2 & see if it still get freeze then their is a problem with console better check it at nearest Sony service center for trouble free working
Jun 29, 2010 | Sony PlayStation 2 Slimline Console
Ps2 game freezes, almost any game...
go here and go to the very end.
www.powerfulguides.com/ps2
hope this helps.
please rate solution ;p
Nov 20, 2009 | Sony PlayStation 2 (PS2) Console
My ps2 slim only works when hold the power lead at an angle.
Its obviously got a fault take it to the store you got it from and get help from techniqucal support
Apr 23, 2009 | Sony PlayStation 2 (PS2) Console
PS2 was dropped, now disc won't spin and can't be read.
I just looked at a friend's PS2. Same story, tripped over cord, unit fell to floor. Unit powers up and sys. config. screen comes on but the drive didn't seem to be spinning up. Opened the case and found that the shaft of the drive motor for the laser tray had popped out of it's centering retainer ( little black bushing/holder). With the top off the unit, looking at the unit from the front, on the right side in the rear corner you'll see the motor. The worm shaft (bronze colored rod) runs towards the front of the unit. Where it ends it should sit centered in a black plastic holder, if it's off to the side a little pressure will pop it back in. Put the cover back on, and power it up, you should hear the drive spinning up. If it does you should be set. Hope this helps.
Mar 28, 2009 | Sony PlayStation 2 (PS2) Console
How to play ps2 game on the ps3
Playing a PS2 game on a PS3 depends on what model your PS3 is. The 40 GB does not play PS2 games, the 60 GB definatly does ,and i dont think the 80GB does
Mar 28, 2009 | Sony PlayStation® 3 (60 GB) Console
New ps2 game won't play on older ps2 game console. Help!?
You're stuck not being able to play, you need to get the slim PS2's because they reconverted the discs for a new disc encoding.
Dec 25, 2008 | Sony PlayStation 2 (PS2) Console
My ps2 wont turn on
Droped it , now your screwed
Nov 15, 2008 | Sony PlayStation 2 (PS2) Console
My sister misplaced the laptop power cord for a ps2 cord now the ps2 wont spin or read discs !
Go to Ebay and put "PS2 Slim power adapter" in the search box on Ebay. Look for a good deal and happy bidding.
Jan 30, 2008 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 Slimline Console Logo
129 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
Lee Hodgson
Lee Hodgson
shevantha perera
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
