Question about HP Pavilion dv1000 Notebook
Whether DDR is compatible for hp pavilion dv1000 or only sdram is compatible. With which ram can i upgrade.
Posted by krishna_mpm on
Anonymous
    New Friend:
  • 12 Answers
Memory Upgrade for HewlettPackard Pavilion dv1000 Laptop, the HewlettPackard Pavilion dv1000 Laptop takes the PC2700 DDR SDRAM SODIMMs Memory Type, and comes installed with of Memory. You can upgrade your HewlettPackard Pavilion dv1000 Laptop to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory, already with standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Choose the following Memory Upgrade for HewlettPackard Pavilion dv1000 Laptop.
256MB Module 256MB-DDR333, 333MHz, PC2700, 200p SODIMM, 2.5v, Sync
512MB Module 512MB-DDR333, 333MHz, PC2700, 200p SODIMM, 2.5v, Sync
1GB Module 1024MB-DDR333, 333MHz, PC2700, 200p SODIMM, 2.5v, Sync
can also check the link: http://www.crucial.com/upgrade/compatible-memory-for/HP+-+Compaq/Pavilion+dv1000+Series/list.html
For futher and any other technical troubleshooting contact, [email protected]
Posted on Jan 06, 2010
Don Matthews
    Sergeant:
  • 309 Answers
DDR SDRAM (2700) Upgradeable up to 2 gig.
DDR = Double Data Rate, SDRAM = synchronous dynamic random access memory
(or also known as DDR SDRAM)
    Guru:
  • 441 Answers
According to the maintenance manual only 266Mhz Ram can be added to the notebook.
This would be SDRAM.
Hope this helps!!
Kind regards!!!
Hi i have a desktop of HP it have a speed of 3.06MHZ and mother board is 915 can i upgrade the ram up to 4Gb
Mr. Ajay Verma I'm sorry to say but *********** board doesn't support 4GB RAM, It can only support upto 1GB of DDR SDRAM DIMMs(DDR1) RAM.
Jul 18, 2011 | HP Pavilion a305w (DM181AR) PC Desktop
I want to increase the memory ram of my lap top: HP pavilion ze4910us What kind and how much memory can I install ?
You can upgrade, have a look at the specs;
Pavilion ze4910us Memory Specifications Standard Memory 512 MB (removable) Maximum Memory 1.0 GB Memory Expansion 2 sockets Memory Comments PC2100/2700 DDR SDRAM SODIMMs CPU Type 1.4GHz Intel Celeron M 330 Model Comments 400MHz FSB Memory Upgrade for HewlettPackard Pavilion ze4910us Laptop, the HewlettPackard Pavilion ze4910us Laptop takes the PC2100/2700 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your HewlettPackard Pavilion ze4910us Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Choose the following Memory Upgrade for HewlettPackard Pavilion ze4910us Laptop.
Hope that helps.
Dec 15, 2010 | Computers & Internet
DDR Pc3200 400 is so expencive what can I relpace it with
Hi
Unfortunatley you will not be bale to upgrade as the maximum memory the motherboard supports is 1GB
Please can i ask that you leave feedback and vote if this has been useful
Feb 11, 2010 | HP Pavilion a1610n PC Desktop
What is the maximum Ram supported bu Intel 1.86
Your system has a maximum capacity of 2 GB of SDRAM - 266.0 MHz
Jan 05, 2010 | HP Pavilion dv1000 Notebook
What is the maximum memory for this computer?
This computer (HP Pavilion a620n) has 2 x 184-pin DDR DIMM sockets and supports up to a maximum 2 GB of memory. It supports unbuffered PC2700/2100 non-ECC DDR SDRAM memory. (Also known as DDR333 and DDR2100 respectively)
Oct 27, 2009 | HP Pavilion a620n (PC028A) PC Desktop
I have hp dv-1000 laptop with 256 ram, which i wud like to upgrade to maximum.so how many GB ram i can go for and what wud be the price.?Can i go for 4GB ram?
You can upgrade to 2Gb ram. I dont think your notebook will support 4Gb ram. A 2Gb Transcend ram will cost you around 1500 bucks INR
Sep 01, 2009 | HP Pavilion dv1000 Notebook
Hp system board
the machine uses ddr 1 memory and hold a max of 2 gb of ram
RAM 128/2700 MB DDR SDRAM
Maximum 2 GB (2x1024MB DDR SDRAM)
Sockets Two 184-pin DDR DIMMs
Size 128, 256, 512 and 1024 MB DDR DIMMs
the motherboard is a socket 478 board , the Dual-Core chips are socket 775 so you couldnt use them unless you change the motherboard
Dec 08, 2008 | HP Computers & Internet
Computer memory upgrade
Standard Memory 256 MB (removable) Maximum Memory 2.0 GB Memory Expansion 2 sockets Memory Comments PC3200 DDR SDRAM DIMMs CPU Type 1.6GHz Intel Pentium 4 Model Comments 400MHz FSB
- Always believe HP - its there product - Staples is not the manufacture.
Jul 22, 2008 | Computers & Internet
Graphics card upgrade
Not compatable at all.
DDR SDRAM memory uses 184 Pin Dimms
Double-Data-Rate Synchronous Dynamic Random Access Memory, better known as DDR SDRAM or DDR RAM for short, is a type of very fast computer memory. DDR RAM is based on the same architecture as SDRAM, but utilizes the clock signal differently to transfer twice the data in the same amount of time.
DDR2 SDRAM uses 240 Pin Dimms.
DDR2 SDRAM improves on DDR SDRAM by using differential signaling and lower voltages to support significant performance advantages over DDR SDRAM.
If your question has to do with buying a video card that is going to use DDR2 ram, that would be a faster graphics card. You can also get video cards with DDR3 ram which again is even faster.
Oddly enough in respect to system memory DDR2 is supposed to be faster than DDR yet the DDR memory cost more than the DDR2. Go figure.
Click the link for video cards.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=318&
http://www.google.com/search?hl=en&q=XFX+AGP+8x+512MB+DDR2+video+card&btnG=Search
Need help with anything, feel free & ask.
Have a great weekend!
Mike
Mar 21, 2008 | Foxconn P4M800P7MA-RS2 Motherboard
HP Pavilion dv1000 Notebook Logo
521 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Toby Lee
Toby Lee
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
