well this is a hardware problem.in this case your charging stage is not work.i am showing you a picture in the yellow marking fat 's are shorted if you can change these components the issue will be solved.sorry for bad english.
the battery wont stay charged? if youre putting in a fully charged battery and your car runs, but then the battery slowly dies, the problem will be your alternator. the alternator is what maintains a car batteries charge. try replacing the alternator. hope this helps.
Ifthe recharable battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall.
ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time.
Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Did you mean charged or changed?
If charged, it could be battery has lost depth of charge. You can charge a "tired" battery for hours only to have "surface charge". Just doesn't charge deep into the plates like it used to.
If changed - did you get a big enough battery? That 750 (12 cyl) is a monster on battery and your electrical system is almost in the NASA sphere of complications.
When you receive a new battery unless you get it from a local dealer you will have to fill with acid before charging. The acid is usually supplied in a plastic bottle with the battery.
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
steps...
1) check by using another charger...if it gets charged then change ur charger..
2)if its not getting charge then replace the battery and then try charging...if its again not working then battery problem..change it
3)if the battery s in proper condition then the problem s with the phone charging socket..change it for cost!!!!!!!!
y hp6365 keeps telling me that i my backup battery is low..i keep
charging my phone but the only the main battery is charging..how do i
charge or change the backup battery?
