Question about Lexmark Pro X125 All-In-One InkJet Printer
Tried to print and it says remove paper jam and press start, tried that several times, put more paper in, powered off and it stil says paper jam...opened it up and no paper i can see thats jammed..
Posted by chief_allpoi on
Anonymous
    Novelist:
  • 181 Answers
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Posted on Jan 12, 2010
Carriage jam message...........comes on no matter what.........reset several times
Give a call to HP Tech support team they will try to resolve your issue. You can contact them (877-690-9305) Support For Hp Printer
Jun 21, 2011 | HP Photosmart C5280 Printer
Light is flashing on Resume on my HP Deskjet F2110 All-in-One printer scanner copier. What does that means?
Regular paper, envelopes, or specialty media may get stuck or jammed in the printer. Follow the instructions below to find and remove jammed paper (or other media) from the printer. If the HP All-in-One has a paper jam, first check the rear door. If the jammed paper is not in the rear rollers, check the front door.
Step one: Check for and remove any paper stuck in the paper In tray
  1. Remove all loose paper from the paper In tray.
  2. Press the RESUME button.
    • If the paper jam is cleared, skip to Step Four
    • If the paper is still jammed, continue on to the next step below.
  • If more than one sheet is stuck in the printer, remove the paper, one sheet at a time by taking hold of a sheet in the middle of the stack and, with both hands and firm, even pressure, pull the sheet towards you. Usually, removing one or two sheets from the middle of the stack will release the pressure and the rest of the stack can be removed.
  • After removing the paper, check to make sure no scraps of paper are stuck in the printer.
    • If the paper jam is cleared, skip to Step Four.
    • If the paper is still jammed, continue on to the next section.
  • Step two: Clearing a paper jam from the back of the printer
    If the paper jam is not accessible from the In tray, follow the instructions below to clear the paper from the back of the printer.
    1. Unplug the HP All-in-One.
    2. Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the HP All-in-One. Figure 1: Removing the rear door
      CAUTION:If the paper tears when removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all of the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Replace the rear door. Gently push the door forward until it snaps into place.
    3. Press Cancel to continue the current job.
    Step three: Lift the front cover and slowly remove any jammed paper
    1. Unplug the power cable.
    2. If necessary, pull the input tray down to open it. Then, lower the print cartridge door. Figure 2: Lowering the print cartridge door
      CAUTION:If the paper tears when while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Close the print cartridge door.
      Figure 3: Closing the print cartridge door
    1. Plug the power cable into the HP All-in-One.
    2. Turn the power on.
    3. Press Start Copy Black or Start Copy Color to continue the current job.
    Step four: Verify the print cartridge carriage can move freely
    2. Check to see if the print cartridge carriage can move freely from one side of the printer to the other. If the carriage is to the right and out of plain view, skip to Step Five. Do not try to force it to move if it is hung up on something. [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/note.png" alt="">
      NOTE:Be careful not to force the print cartridge carriage. If the carriage is stuck, forcing it to move will damage the printer.
      • If the carriage does not move, continue with the next step below.
  • Remove the print cartridges.
  • Step five: Reload and test the printer
    Once the jammed paper is removed, verify that the printer is still functioning properly.
    1. Reload the printer with plain paper.
    2. Perform a self-test by pressing and holding the Resume button until the printer starts printing. A test page should print.
    NOTE:Do not put more than 35 sheets of plain paper in the document feeder tray.
  • Gently move the print cartridge to the far right of the printer.
  • Remove the paper from the paper In tray, but do not remove the drawer.
  • Remove the rear access door.
  • With your fingers, rotate the rollers "up" three full rotations.
  • Push the rear access door back into the printer until it snaps firmly into place.
  • Replace the print cartridges.
  • Plug the power cable into the HP All-in-One.
  • Turn the power on.
  • Step six: Service the printer
    Perform all the steps mentioned above. If the problem continues, service the printer.
    Cause Paper jams can be caused by several factors. Follow these guidelines to prevent further paper jams.
    • Insert paper into the paper tray only until it meets resistance. Do not push it farther in.
    • Make sure that the paper is flat in the paper tray and that the guide is adjusted to the width of the paper.
    • Do not add paper while the product is printing.
    • Remove printed pages frequently.
    • Do not use paper that is too thin, too slick, or that stretches.
    • Do not use torn or creased paper. Used paper might cause jams.
    • Make sure that the rear access door is securely fastened.
    Jun 17, 2011 | HP Deskjet F2210 InkJet Printer
    Paper jam printer 3524
    Clear the jammed paper as follows.
    If the jammed paper is removed completely by using the information in the following steps, you can install the paper tray first, and then close the front cover and the printer will resume printing automatically.
    If the printer does not start printing automatically, press the Go button. If the printer still does not start printing, please check that all the remaining jammed paper has been removed from the printer. Then try printing again.
    Pull the paper tray completely out of the printer.
    Pull the jammed paper up and out of the printer.
    Press the cover release button and then open the front cover.
    Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
    Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
    Open the jam clear cover. Pull the jammed paper out of the fuser unit.
    Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
    Pull the Duplex Tray completly out of the printer.
    Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
    Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
    Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
    Put the drum unit assembly back in the printer.
    Put the paper tray in the printer.
    Close the front cover.
    Dec 21, 2010 | Office Equipment & Supplies
    The printer is constantly sending a message- 'paper jam'
    HP Officejet 7200, 7300, and 7400 Series - 'Paper Jam: Clear jam, and then press Enter' Message Displays on the Control Panel Display
    Issue
    During printing, the paper becomes stuck in the all-in-one and the error message 'Paper Jam: Clear jam, and then press Enter' displays on the control panel display.
    Solution
    Use the following instructions to clear a paper jam from the product:
    Step one: Check for and remove any loose paper from the In tray
    Do not try to remove jammed paper from the In tray. First remove any loose paper from the In tray to avoid worsening the jam.
    CAUTION: Always try to remove jammed paper from the back of the printer first to avoid mechanical damage.
    Step two: Clear the jam from the back of the printer
    Follow these instructions to clear jammed paper from the back of the product. If the product is equipped with a two-sided printing accessory, skip to that section.
    Remove the rear access door to clear the paper jam
    1. Remove the rear access door by pressing the buttons on the side of the door and pulling it toward you.
    Figure 1: Removing the rear access door
    Rear access door
    2. Gently pull the jammed paper out of the rollers.
    WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If all the pieces of paper are not removed from the product, more paper jams might occur.
    3. Replace the rear access door. Gently push the door into the all-in-one until it snaps firmly into place.
    Remove the two-sided printing accessory to clear the paper jam
    1. Remove the two-sided printing accessory by pressing in the buttons on the sides and then pulling the accessory toward you.
    Figure 2: Removing the two-sided printing accessory
    2. Gently remove any jammed paper.
    WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the accessory. If all the pieces of paper are not removed from the accessory, more paper jams might occur.
    3. Press the button on top of the two-sided printing accessory to open the door.
    Figure 3: Opening the two-sided printing accessory door
    4. Gently pull the jammed paper out of the rollers.
    5. Close the accessory door.
    6. Reinstall the two-sided printing accessory.
    Step three: Clear the jam from the automatic document feeder (ADF)
    1. Remove the document feeder tray from the product by gently pulling it.
    2. Lift the cover of the automatic document feeder by pulling it outward.
    Figure 4: Lifting the cover of the automatic document feeder
    Automatic document feeder (ADF) door
    3. Gently pull the jammed paper out of the rollers.
    WARNING: In the rare occurrence of a severe paper jam, you might need to remove the face plate from the front of the automatic document feeder and lift the pick assembly to remove torn pieces of paper from deep inside the automatic document feeder.
    4. Close the cover of the automatic document feeder, and then reattach the document feeder tray.
    Step four: Verify that the print carriage can move freely
    Follow these steps to try to move the print carriage.
    CAUTION: Do not force the print carriage to move if it is out of plain view or feels stuck. Forcing it may damage the printer.
    1. With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
    2. Without turning off the product, unplug the power cord from the back of the product. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
    3. Looking in through either the print cartridge access door or the output paper tray, make sure the print cartridges are locked into the carriage and have not come loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving.
    4. Make sure the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found.
    You may have to reach through the output paper tray to access the print carriage.
    5. Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
    6. Press the On button to turn on the product.
    After you have removed the jammed paper, make sure the product is still functioning properly.
    1. Reload the product with plain paper.
    2. Peform a self-test by pressing and holding the RESUME button on the control panel until the product begins printing. A test page prints.
    If you have completed all the steps listed above and are still experiencing a problem, service the product.
    Dec 30, 2009 | HP DeskJet 3745 Printer
    Constant yellow blinking light, no paper jam
    I found this on the HP support site:
    The power light is on, and the resume light is blinking.
    c00109831.gifc01272271.gifc00109834.gif The printer might be waiting to complete a print job or to receive data from your computer.
    Solution
    Wait for the printer to finish the current task. The printer is waiting for the ink to dry on freshly printed paper.
    Solution
    1. Remove the paper with fresh ink.
    2. Press the resume button.
    The printer might be out of paper.
    Solution
    1. Load paper in the paper tray.
    The printer might have a paper jam.
    Solution
    Clear the paper jam. If the resume light continues to blink after the paper jam is cleared,
    OR
    if the print carriage is stuck or making a grinding noise, then follow these steps.
    Solution
    1. Lift the top cover of the printer.
    2. Turn the printer off and then on again.
    3. Unplug the power cable from the back of the printer when the grinding noise starts. Unplug the power cable from the wall outlet.
    4. Movethe print carriage toward the middle of the printer (this proceduremight take a couple of tries to get the timing correct).
    5. Remove the print cartridges and close the top cover.
    6. Plug the power cord into the back of the printer. Plug the power cord into the wall outlet.
    7. Open the top cover, reinstall the print cartridges, and then close the top cover.
    The printer may be ready to eject banner paper.
    Solution
    Press the resume button to eject the banner paper.
    Mar 14, 2009 | HP DeskJet 5550 InkJet Printer
    Jamming problem
    try this
    1. Turn off the printer.
    2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
    3. Also open the back cover of the printer if this model has one.
    4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
    5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
    6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
    7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
    8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
    9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
    10. see alternative if the problem is still not solved.
    alternative :
    Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
    Mar 06, 2009 | Canon PIXMA MP460 All-In-One InkJet...
    Paper jam notification after printing one page, no paper jam
    try this
    alternative :
    Nov 16, 2008 | HP PSC 2210 All-In-One InkJet Printer
    Paper Jam
    try this
    alternative :
    Sep 21, 2008 | HP OfficeJet 4315 All-In-One InkJet...
    Printing troubles
    Paper jam:
    Clear the paper jam. If the printer does not start printing, press the control panel button.
    No paper:
    Put paper in the printer. Then press the control panel button.
    Misfeed:
    Put the paper back in properly, and then press the control panel button. The printer will start printing again.
    Mar 24, 2008 | Brother HL 1440 Laser Printer
    Canon S 520 doesn`t print
    Two flashes: Out of paper, paper jam or paper feed error
    Replace the paper correctly and press the RESUME/CANCEL button.
    If paper has jammed in the printer, clear the jam and press the RESUME/CANCEL
    button.
    Three flashes: Paper jam
    If paper has jammed in the printer, clear the jam, replace the paper in the printer
    Four flashes: Empty ink tank
    One of the ink tanks is empty. Replace it.
    Six flashes: No print head installed
    Install a print head.
    Seven flashes: Defective print head
    Remove and reinstall the print head.
    Also, ensure that the protective tape has been removed. If reinstalling the print head
    does not resolve the problem, replace it with a new one.
    Eight flashes: Waste ink tank almost full
    The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight
    flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL
    button to cancel the error so you can continue printing. Before the waste ink tank
    becomes completely full, contact a Canon service representative to have the waste ink
    tank replaced. Canon recommends to call for service as soon as this error occurs. Once
    the waste ink tank becomes completely full, printing will be no longer
    possible.
    Oct 19, 2007 | Canon S520 InkJet Photo Printer
    Lexmark Pro X125 All-In-One InkJet Printer Logo
    131 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Muntejaya Ginting
    Muntejaya Ginting
    CheckitRight
    CheckitRight
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
