Question about Tomtom ONE 130 GPS Receiver
My tomtom 130 apps are in a foriegn language and I have no idea how to program it
Megasom
  • 699 Answers
Your TomTom One has been set to a foreigh language: you need to change the default back to any version of English (US or UK) that is available:
It is normally done under 'Change preference' (look for Spanner image Icon) -> Scroll right Arrow until 'Change language' (look for Flags image Icon) -> Select English -> Select an English Voice
Just look for the graphic when you bring the menu up as it will be in whatever language!
Hope it helps: let me know how you go.
Posted on Jan 07, 2010
Testimonial: "THANK YOU, THANK YOU, THANK YOU I have spent many hours with the help of family and friends to fix this problem and YOU DID IT."
  • Megasom Jan 07, 2010
    I am glad you are back on track!
    Make sure that you use TomTom Home to backup and update your working device on a regular basis.
    You can also download additional 'free' voices from TomTom Home.
    Thank you for the feedback and acknowledgement: it is always appreciated!
Radio Code Pro
  • 2,200 Answers
Please view this FixYa Tip which is illustrated to more easily explain the process that is involved.
Thanks for using FixYa and please do leave a vote for the solution if it helps.
Posted on Feb 05, 2010
Need Usage Manual for TomTom 130 Canada 310
This manual is available for you to download here. Its approx midway down the page and is the 125/130 series manual
http://www.tomtom.com/support/support.php?ID=3&Language=4
Thanks for using FixYa.
Feb 04, 2010 | Tomtom ONE 130 GPS Receiver
Cannot get our new Tomtom GPS one 130 to show English in instruct
Connect your device with TomTom Home and access the memory (like if it was an external disk)
Create the following 2 files without ant extension in the root:
cleanflash
runclean
It will reset your devide to the original settings.
When starting it will ask you which language you want to use.
Jan 01, 2010 | Tomtom ONE 130 GPS Receiver
How do i change the language on my tomtom 130
Please view this FixYa Tip which is illustrated and helps to more easily explain the process.
Dec 26, 2009 | Tomtom ONE 130 GPS Receiver
TomTom Home software appears in a different language
You can reset your language by following this tutorial on TomTom's Website
Dec 26, 2008 | Tomtom ONE 130S Car GPS Receiver
Wrong lanaguage on tomtom 130-s
This was answered in another post- here
While this is for the 130, the interface on the 125 is nearly identical- look for a sunshine icon for the preference button and lips for voice/language
Dec 25, 2008 | Tomtom ONE GPS Receiver
Reset
Start up your TomTom and find the preferences icon. The lips icon has the option of changing the voice, and you can switch back to English from there.
Oct 17, 2008 | Tomtom ONE 130 GPS Receiver
Open Questions:
My tom tom one 130 stays with an orange picture, and a red circle with an X. It also says something about an error when I try to upgrade it... like this.... ERROR: Internal/Malformed#createItemFromDLL/Internal/Malformed: Exception: Lo sentimos pero HOME no puede completar esa tarea. Inténtelo de nuevo más tarde o póngase en contacto con el departamento de atención al cliente. Para resolver los problemas con los elementos almacenados en su dispositivo, le recomendamos eliminar y volver a instalar el elemento. Malformed Item info: name = id = version = 0 locationType = 1252 install location physicalType = 1504 metadata = Severity: 1105 - Internal/Malformed: Malformed: Lo sentimos pero HOME no puede completar esa tarea. Inténtelo de nuevo más tarde o póngase en contacto con el departamento de atención al cliente. Para resolver los problemas con los elementos almacenados en su dispositivo, le recomendamos eliminar y volver a instalar el elemento. Must not be empty Bad value: "" (type: string) Severity: 1105 Stack: 0. chrome://tthome/content/logic/model/ttItemFactory.js:43 let wrapper = new Exception(null, newId); 1. chrome://tthome/content/logic/model/ttItemFactory.js:90 var modelitem = this.createItemFromDLL(dllitem, onlyType); 2. chrome://tthome/content/logic/model/ttItemList.js:55 var models = gApplication.itemFactory.createItemListFromDLL(dllItemList, onlyType); 3. chrome://tthome/content/logic/ttTask.js:315 itemList.addItemListFromDLL(doneLocation.deviceNavItems()); 4. chrome://tthome/content/logic/util.js:79 return func.apply(obj, arguments); 5. chrome://tthome/content/logic/dllUtils.js:73 this._successCallback(this.successText); 6. chrome://tthome/content/logic/dllUtils.js:58 this._success(); CAUSE: Internal/Malformed: Malformed: Lo sentimos pero HOME no puede completar esa tarea. Inténtelo de nuevo más tarde o póngase en contacto con el departamento de atención al cliente. Para resolver los problemas con los elementos almacenados en su dispositivo, le recomendamos eliminar y volver a instalar el elemento. Must not be empty Bad value: "" (type: string) Severity: 1105 Stack: 0. chrome://tthome/content/logic/serverinput.js:84 throw new Malformed("Must not be empty", uc); 1. chrome://tthome/content/logic/serverinput.js:218 var str = this.nonemptystring(uc); 2. chrome://tthome/content/logic/model/ttNavItem.js:265 this._idstr = makeSafe.contentidstr(item.id); 3. chrome://tthome/content/logic/model/subtype/ttVoice.js:36 ttNavItem.prototype.importFromDLL.apply(this, arguments); 4. chrome://tthome/content/logic/model/ttItemFactory.js:39 result.importFromDLL(item); 5. chrome://tthome/content/logic/model/ttItemFactory.js:90 var modelitem = this.createItemFromDLL(dllitem, onlyType); 6. chrome://tthome/content/logic/model/ttItemList.js:55 var models = gApplication.itemFactory.createItemListFromDLL(dllItemList, onlyType); 7. chrome://tthome/content/logic/ttTask.js:315 itemList.addItemListFromDLL(doneLocation.deviceNavItems()); 8. chrome://tthome/content/logic/util.js:79 return func.apply(obj, arguments); 9. chrome://tthome/content/logic/dllUtils.js:73 this._successCallback(this.successText); 10. chrome://tthome/content/logic/dllUtils.js:58 this._success();
Aug 17, 2010 | Tomtom ONE 130 GPS Receiver
See all Tomtom ONE 130 GPS Receiver Questions
Tomtom ONE 130 GPS Receiver Logo
352 people viewed this question
Top Tomtom GPS Experts
k24674
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
