IBM Lexmark X83 All-In-One InkJet Printer Logo
Question about IBM Lexmark X83 All-In-One InkJet Printer
My X83 will not print color, even with new color cartridge. I have cleaned the new cartridge to be sure ink flows (it does) and cleaned the cartridge holder. Not even a hint of color shows as if it were set on black only, even for the test page. Any suggestions?
  • Anonymous Jan 06, 2010
    It will not print a color test page when program settings are on color or when done from the printer itself.
Anonymous
    New Friend:
  • 67 Answers
There is a setting to make everything black and white on the printer. You may need to change this in the printer menus.
Posted on Jan 06, 2010
Pro 8500 printer. Just installed new color ink cartridges. Why isn't color printing on printed material?
Hello, Take the ink cartridge out and dab on a wet paper towel until the ink start flowing or the ink cartridge is bad or the print head needs to be cleaned on the printer.
Lexmark X83 wont print color, even with new cartridge
Check printer properties. Right click on printer > Properties > Printing Preferences > Paper / Quality. Color. These are default menus, but may vary with printer driver.software.
3helpful
Hp psc 750 won't print with new color ink cartridge
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
1helpful
Lexmark x1270 poor printing
Try these steps after these if you face the same problem then you need to get the cart exchanged as it may be defective as Lexmark cart comes with 6 months warranty ...
Lexmark x83 problems
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Lexmark X83 Problem
be sure to delete your printer and reinstall the printer cd back again but be sure there is only one printer install on your control panel .
Lexmark X83 printer has streaks printing color pictures (but text is fine)
This is the problem with the cartridge if you brought original Lexmark cartridge you can get it exchanged as the cartridge is nay be defective and the cartridge comes with one year warranty...........................................
0% color ink
We cannot bypass the color ink check, since the all-in-one uses little amount of even the color ink to print in black. Once check the expiry date of the color cartridge and clean the copper contacts of the cartridge and reinsert it again and then try to print. If the issue still persists replace the color cartridge and check for the result, if we experience the same issue even after replacing the color cartridge then the issue is with the all-in-one.
1helpful
3answers
Lexmark X1185 won't Print Color
On your printer, there is a clean print head adjustment,it is in your menus on the printer itself, It should also be on your print driver in properties. I would try running that up to 5 times before proceding to anything else.
Check and be sure the cartridge expiration date is not exceded. The liquid ink cartridges have an expiration dates. Even though the cartridge is new, Do not rule out a bad or for some reason dryed out cartridge or blocked port at the bottom. If it is indeed brand new and you have the receipt, I honetsly would suspect the cartridge itself.
Ok now, we tried the print head cleaning, and a second cartridge.
Next, I would remove the cartridge, turn the printer off and lightly, very lightly dampn a dusfree cloth with some alcohol, and where the cartridge is located, clean those contacts. reinsert the cartridge and see what happens.
Lastly, you can unplug the printer, remove the cartridges, and place a paper towel under the area where the cardtidge latches in, and dribble in a soapy cleaner, like fantastic, because those inks will dry out in the ports and not allow the ink to flow properly, If you do that, wipe all the excess cleaner up and leave the printer off for an hour or two to allow any remaining liquid to evaporate. Don't use a lot, but trickle it in until you see the ink start to wash out and all the ink is removed.
Take your time, and go from easiest to more difficult. I think that is the process I presented.
Top IBM Office Equipment & Supplies Experts
Gary
Gary
Fix It Fast...
Fix It Fast...
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
