Canon Pixma MX860 fax problem. Connected to network -a Mac and a PC. Fax settings are correct.One Phone Line. After Fax has been utilized it interferes with phone service with a constant fax signal.
faxing requires some type of Phone connection in most instances, network faxing is another set of drivers that need to run on your PC, the same as phone line faxing that utilizes your modem (as long as the modem is fax capable) the issue you have is the way it is set up. first off you have to have the communications between the printer and the computer running properly. If you do not have a router with a wifi connection and the printer is connecting directly to the computer wirelessly, you need to make sure it is set for peer to peer networking, if you have a true network using a router and wifi (more than one computer can connect to it, you need to make sure you are set for that. Remember, you are not faxing from the printer if it is not connected to a phone line, you are faxing from your computer. and you need to make sure you are running the correct type of fax software, for network faxing or dial up (phone line) faxing.
Make sure you have pluuged the telephone line lead into the "LINE" socket and not the "TEL" socket of the fax machine. I reckon thats why you are not dialling out correctly. If this is in an office, make sure you are dialling the access number for an outside line, usually a 9 before the phone number.
Typically a fax machine will use the phone line to communicate with other fax machines. There is a port on the back that you can plug a phone line into. I think it is the one below the port that looks like a phone handset.
Use your operating system to choose the printer rather than the driver. For Windows XP, go Start, Settings, Printers and Faxes. Right click on the printer and choose Set as Default Printer.
first make sure it is connected and On. then go to Printers nd fax, and select it. If not there click on add printer and follow the directions and that should do it.
Press the FAX button, open the document tray and align the paper guides for A4 size paper.
Place the sheets in the document feeder, facing up, first text line towards the machine, first page on top. The machine will beep. Adjust the paper guides.
Enter the phone number, and press the black button. The fax will be sent with the default settings.
Refer to the user manual as to how to change settings (it's quite straightforward from the menu, anyway).
I just noticed that I had the telephone cable connected to the "Telephone" port on the back of the Fax/Printer. When I switched it to the "Line" port, suddenly the clicking stopped and the Memory/In Use light went off. Now we will see if I can Fax something. Hope this works for you too!
I am having a similar problem. You do have to connect your phone to the jack in the machine in the "Phone" jack slot, as well as have another line out to the jack in the wall in the "L" slot. That is all I know. I am having problems with my voicemail. Either I can received voicemail, and no faxes, or faxes, and no voicemail (fax picks up at specified number of rings). It is EXTREMELY frustrating. The machine is *supposed* to be able to discern between phone calls and faxes..and that is not happening.
Is your phone line plugged into the proper receptical on the fax? It should be plugged into the LINE slot, not the PHONE slot. The PHONE SLOT IS TO CONNECT A TELEPHONE TO THE FAX. IT IS NOT FOR THE INCOMING PHONE LINE. If your phone connection is correct, try calling your fax machine from a cell phone while you are at the fax machine. Listen on the cell to see if the fax machine picks up the line. If it does not, go into your fax machine's settings, either INITIAL SETUP FAX SETUP, or PHONE SETTINGS. You may have to try several settings to find one that works, depending on your fax machine. Try going to RECEIVE SETUP on your fax machines setup menu. Scroll through the settings, writing each down on paper. Try RING DELAY, RING TIME, NUMBER OF RINGS TO ANSWER , or any other settings relating to how your fax answers the phone line. Try changing each setting, one at a time, and try calling your fax to see if it answers. There may also be settings on your fax to set it up if an answering machine or telephone is on the same line.
