I have an 01 Jeep Cherokee Sport. I am having heating issues. It heats up to about luke warm and that's it. I have replaced the thermostat twice and coolant level is normal. Also there is no pressure on the top hose when running.
As soon as the vehicle reaches around 180/195 (depends on the temp of the t-stat) the thermostat should open and thereby filling the top hose with warm/hot water.
Are you sure the thermostat is facing the right direction? Is the cooling system full?
Here is what you can do: remove the t-stat, replace any lost coolant/water and run the vehicle with heater on full blast for about 15 minutes or until the temp gauge is showing about halfway. During this time be sure to monitor the coolant level in the reservoir.
If you still have no hot air you may have a blockage or perhaps the heater hoses are not even connected.
