Broiler does not heat. bake is fine though it seems to take an unusually long time to get to the set temp
Sounds like a problem in the relay control board. (aka Transformer Relay Board)
If you are comfortable removing the oven from the cabinet (easy!!) and tilting the control panel out a bit, the Broil control relay is the 2nd one from the end on this pic:
If you wanna take it a bit further, and feel comfortable poking around with a DVOM with live power to the board (not recommended for the novice), check relay K5 for 120V on E-12 (blue wire). If you have it, hit the "Broil" button, set it to "high", and check E-13 (black wire to the left of blue wire) for 120V. If you don't have 120V to E13, chances are the relay has flaked out on you.
If this is right down your alley, definitely spend some QUALITY time reading these manuals, they will help you isolate the problem.
http://www.servicematters.com/maytag_library/docs/16021875.pdf
http://www.servicematters.com/maytag_library/docs/16021876.pdf
