Question about Plantronics Discovery 640 Wireless Headset
No sound from my plantronics 640 earpiece?
Hi- for some reason my ear piece~ plantronics 640 sound disappeared? i thought maybe i did not charge it completely so recharged it. that doesnt seem to be the problem. shut it down as well as phone... to no avail? has it met its last day? have you heard if this has happened to anyone else. its several yrs old now.
6ya staff
SOURCE:
Anonymous
SOURCE: Passcode for Plantronics 640
I heard 0000 is the default code
Posted on Dec 11, 2007
aspaulding2c
SOURCE: plantronics ear piece
i need a passcode for my bluetooth so i can put it on my blackjack
Posted on Feb 29, 2008
Anonymous
SOURCE: need pin for plantronic bluetooth
try inputting 4 zeros, that's 0000
Posted on Mar 05, 2009
Anonymous
SOURCE: how do i connect phone with m2300 ear piece
Begin with Headset turned off. Press button for 6 sec. Release button when Light Indicator flashes blue and red. Headset is ready to pair with Bluetooth device. Use your device?s menu to enter pairing mode and select ?320 Plantronics? on the display. When asked for passkey, enter ?0000.?
Posted on Jun 10, 2009
Anonymous
  • 4 Answers
SOURCE: How do I replace the ear cushions for a Plantronics DSP 400?
There are some small silver inserts on the side of each earpiece. You can pry them off (gently) starting under the cushion and working your way around.
You can then remove the old cushions and put in the replacements and snap these silver retainer inserts back on.
You can get replacement cushions online for about $16.
Posted on Nov 12, 2009
Hi, I have a Plantronics BackBeat 903+ and I have a big problem with it. It seems to have a bad contact some where in the left earpiece that every time I just touch it it turns off immediately. Can...
It sounds like there may be a short in the headset. If you are just touching the ear piece and then you hear nothing on that side. If that side has been damaged at all you might want to check for manufacture cracks or loose wiring. If your Plantronics Backbeat 903 is still under warranty you should be able to get another one.
Good luck from Headsets Direct!
Sep 05, 2011 | Plantronics Backbeat 903 Bluetooth...
Need to know how to change the earpiece to a smaller piece for the inner ear
Plantronics has a very nice of ear tips for the CS70 that includes several sizes, so you can find one to fit your ear. Here is a link where you can purchase the set of ear tips:
Plantronics Replacement Ear Tips
Mar 28, 2011 | Plantronics CS70 Wireless Headset
How do I sync my replacement ear piece
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone, PC or other device for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
1 Turn on the Bluetooth feature on your phone.
2 Turn the earpiece on. Press and hold the call control button until the indicator flashes red/white.
3 Use the commands on your other device to locate and select your earpiece. 9xx Plantronics.
4 If prompted for the PIN code or Passkey, enter 0000.
Pairing is successful when the indicator on your earpiece flashes white.
Note If your phone supports Secure Simple Pairing (SSP), you will not need to enter a PIN code or Passkey.
Dec 08, 2010 | Plantronics CS70 Wireless Headset
How do I get my plantronics ear piece in discoverable mode?
What plantronics earpiece? Model?
Why is this posted in Motherboards, which is a computer component.
Aug 13, 2010 | Computers & Internet
New - but will not charge up (no light on earpiece).
probably the wire from the charger is bad. Try to replace the charger
May 20, 2009 | Plantronics Explorer 340 Wireless Headset
Lost the manual - how do I turn the earpiece volume up
Yes. Just move the button on the ear-piece in an "up"position while you have it on..
Jan 22, 2009 | Plantronics Explorer 320 Wireless Headset
Ear piece does not work. Station top light does not come on
The 500A base station is definitely compatible with the 510 earpiece. If the earpiece is turned off or unpaired the base station's red power light will be flashing. If the earpiece is already off, try turning it on by holding down the little black button on top. The base station will automatically try to find the earpiece and the blue light on top of the base will come on. If the earpiece is already on (slow flashing blue light on the mic boom) turn it off and back on again and wait for the base to find it.
Nov 10, 2008 | Plantronics - Bluetooth Headset Plus Base...
Plantronics Explorer Plantronics Explorer
That is the job of the ear piece to keep the device in the ear
Jun 19, 2008 | Plantronics Explorer 320 Headset
Plantronics ear piece
Dec 06, 2007 | Plantronics Explorer 320 Headset
Earpiece vibrating & heating
do you know if the codes of the headsets are the same i lost mine and i need help
Aug 17, 2007 | Plantronics Discovery 640 Wireless Headset
Plantronics Discovery 640 Wireless Headset Logo
112 people viewed this question
Top Plantronics Radio Communications Experts
Anthony Ward
Anthony Ward
gggg
edward80
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
