Question about Digital Products Digital DECserver 732 (DSRVW-KC) Terminal Server
Access server manager 3.6
Posted by ryan_haller on
Jon Stanley
    New Friend:
  • 4 Answers
The ASM (Access Server Manager) utility comes with the DECserver. You can purchase ASM from the site listed. ASM manages Conx4, DS90M+, DECserver 700/7XX, and DS900-TM. The current version is V3.6. ASM is an IP based utility and is supported on most platforms (verified Vista- 2000). mMange communicate and backup/restore are features of the utility.
Posted on Aug 12, 2010
  • Jon Stanley Apr 11, 2016
    Anybody trying to use the DECserver as a teminal needs to remember that the async interface is a 423 DECstd configuration. That said, on the receive side, either at the DTE equipment on someplace, pin 1 has to be configured to GND (pin-3 of a 9-pin D connector), or purchase the H8585-AAG adapter. This adapter is built for RS-232 compatability.
Joaquim Martins
    Genius:
  • 1,127 Answers
The DECserver 732 is a high-density, high-performance asynchronous device and remote access server that provides 32 MJ8 (RJ45) serial ports. The DECserver 732's serial ports support either of two sets of software-selectable four-signal modem control signals. The DECserver 732 has AUI and 10BaseT Ethernet connectors. The DECserver 700-16 supports up to eight sessions per port and speeds up to 115.2 Kb/s per port. The DECserver 732 has an external FLASH socket for the customer-installable flashcard. When installed, the flashcard allows self-booting operation. The DECserver 732 runs DECserver Network Access Software (DNAS), which delivers multi-protocol support for TCP/IP, IPX, and AppleTalk networks. DECserver 700 units are designed for tabletop or rackmount configuration
the u need to check these site for more info:
http://www.vnetek.com/s-137-digital-networks.aspx
Posted on Jan 06, 2010
How to access Cisco Unified Communications Manager Administration ?
from what I have researched on the web you need to download the Cisco unified Communications Manager software on to the P.C you wish to use to access the server via the web browser. it states you open the software via a web browser. The reason being the Voip server has no software on it.
http://www.cisco.com/web/developer/cucm/content/download.html
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/11_5_1/CUCM_BK_A09578D7_00_admin-guide-cucm-imp_1151/CUCM_BK_A09578D7_00_admin-guide-for-cucm-1105_chapter_01.html
Apr 20, 2016 | Cisco 7940 IP Phone
Windows could not load the installer for NHCI. My printer is visible on the Keyspan server but I cannot print to it.
go to device manager and find the kepsan server, right click on the keyspan server with the yellow exclamation mark and say update driver, allow access to internet and it should install the driver...worked for me
Sep 01, 2010 | Keyspan USB Server US-4A (d47710) Print...
Unable to access email account on acer net book . i have a laptop running blueyonder broadband,when i try to connect my netbook to my outlook express email account i get unable to access the mail server.
Hi
This sounds like your user account settings are not correct and need to be input via the account management section to look like the following:
  • Customer Email format - [email protected]
  • Outgoing Mail Server - smtp.blueyonder.co.uk
  • Outgoing server type - SMTP
  • Incoming mail server - pop3.blueyonder.co.uk
  • Incoming server type - POP3
  • Password - for example, Rich4rd1
  • Thanks
    Taz
    Oct 30, 2009 | Acer Aspire One Netbook 8.9" Notebook
    Dhcp in server 2003 in domain not working
    Windows 2003 server supports DHCP. If you don't see in Administrative tool DHCP maybe the DHCP role is not enabled. You can add this role in "Manage your server". You don't need to reinstall win 2003 server.
    Another way to access DHCP management tool is: in command prompt type mmc and then File> "Add remove snap-in" then "Add" and select DHCP.
    Jan 06, 2009 | Microsoft Windows Server Standard 2003 for...
    Access files
    Sharing is not enough on windows server 2003. You will need to give privilages to the Everyone user on that folder and enable the Guest user from the Computer Management/Users and Groups panel.
    You can also create a new user from there. Give it security and sharing privilages on that folder. And login with it from the other computer.
    Oct 28, 2008 | Computers & Internet
    OOBM what does it stands for?
    Out-of-band Management. This refers to using a network or other management connection to the router that is not part of the normal data flow in and out of the router. For example, if you connect a dial-in modem to the router's console port and manage it through a phone line...this is considered out-of-band-management because you're not using normal communications bandwidth.
    Jan 17, 2008 | Cisco Universal Access Server AS2511-RJ...
    Changing the IP address
    check with the manual of the server that it is having web based management. If yes make your computer ip and subnet mask as per the ip and subnet mask of print server. open the internet explorer type the url as specified in manual enter the username & password as per manual. there will be the setting page displayed where you van change th eip of the print server. if not please write me which type of management it uses to access the settings.
    May 10, 2007 | Emulex NetQue Pro2 (NP02) Print Server
    Digital Products Digital DECserver 732 (DSRVW-KC) Terminal Server Logo
    831 people viewed this question
    Top Digital Products Computers & Internet Experts
    Muntejaya Ginting
    Muntejaya Ginting
    Marvin
    Marvin
    Are you a Digital Products Computer and Internet Expert? Answer questions, earn points and help others
