Question about Mad Catz PS3 Bluetooth® Headset Wireless Headset
How can i find my pass code - Mad Catz PS3 Bluetooth® Headset Wireless Headset
Posted by d_brunson95 on
Anonymous
    Scholar:
  • 100 Answers
Hi there. Usually for bluetooth headsets the passcode is "0000" or "1234". Try it, hope it helps.
Posted on Jan 05, 2010
Set combination for paragon lock & safe
TO SET UP OR CHANGE A USER CODE
1. With the door open, locate the red button on the back of the door near the hinge.
2. Press the red button and listen for the beep.
3. Immediately enter your new pass code (3-6 digits long)
4. Immediately after entering your new pass code, press the "A" or "B" button on the keypad. Your new user pass code is now stored.
NOTE:
This safe stores up to 2 pass codes (a user code and a manager code). Entering a third code will erase the
first pass code entered.
SETTING UP OR CHANGING A MANAGER PASS CODE
1. Open your safe with the pass code you wish to change and leave the door ajar.
2. Press the "0" button on the keypad twice. Press the red button, listen for a beep and then enter your new user pass code.
New user pass codes may be 3-6 digits long.
3. Immediately after entering your new code, press the "A" or "B" button on the keypad. Your user code is now changed.
http://www.paragonlockandsafe.com/manuals/mastermanual.pdf
How do i change the password on my nook
Recover a Nook Password
Nook users can enable a pass code to prevent unwanted access to the device.
If you forget your device pass code, you won't be able to recover it.
You can reset your pass code and create a new one by using your Barnes & Noble account credentials.
Attempt to input your pass code three times.
Once you have failed to unlock the Nook three times, you will be prompted to "Start Over" or "Disable pass code using account credentials."
Tap "Disable pass code using account credentials" in the menu.
Enter your Barnes & Noble email address and password.
Tap "Submit" to disable the pass-code protection.
Enable New Pass Code
Tap the Home button and select "Settings" from the icon menu. Tap "Device."
Tap "Enable Pass Code" from the menu that appears.
Enter a unique alphanumeric pass code, then confirm it in the text-entry fields.
http://www.barnesandnoble.com/nook/support/
I forgot my family settings pass code and reset code for the xbox 360
Reset a Forgotten Pass Code To reset your Family Settings pass code after you've forgotten it:
  1. From the System area of the Xbox Dashboard, select Family Settings, Console Controls.
  2. Enter an incorrect pass code.
  3. You will be told that your pass code is incorrect. Select Reset pass code.
  4. You will then be shown your pass-code question and asked to answer it.
    Type your answer using the on-screen virtual keyboard and either your Xbox 360 controller or a standard USB computer keyboard plugged into a controller port on your console. Your answer is case-sensitive and must be typed exactly as you entered it originally. This will clear your original pass code and allow you to enter another.
9helpful
3answers
I forgot my family passcode and the answer to the secret question on my xbox 360 what should i do?
Hi aureliogovea
Please everyone that comes across my info take a few seconds of your time to rate my solution which you can select at the bottom of my answer Was this solution helpful? YES or NO :)... As i have taken time to answer your question the best i can Thank You......
If children use your Xbox console, you can set a pass code to control access to features and options. Because Family Settings exist for both the console and for Xbox LIVE accounts, you can set pass codes for both.
Here you can learn how to:
Set an Xbox LIVE Pass Code
When you set an Xbox LIVE pass code for your profile, anyone who wants to use that profile will need to enter the pass code before signing in to Xbox LIVE.
To set an Xbox LIVE pass code:
  1. Go to My Xbox and open your profile.
  2. Select Manage Account, Xbox LIVE Pass Code.
  3. Enter a four-button code using the X andY buttons, triggers, bumpers, and directional pad on your controller.
  4. Confirm your code by entering it again.
To reset your pass code, repeat this procedure at any time. (You will have to enter your original Xbox LIVE pass code before you can create a new one.)
Set a Family Settings Pass Code
When you create a Family Settings pass code, anyone who wants to change family settings on your console will need to enter the pass code first.
You can also use your Family Settings pass code to override game and movie settings if you (or those with whom you share your pass code) want to play games or watch DVD movies that your console settings normally block.
For example, you could give the pass code to your 18-year-old so that she can watch R-rated movies that your younger child is not allowed to see.
To set a pass code for your console:
  1. Go to My Xbox and open System Settings.
  2. Select Family Settings, Console Controls.
  3. Select Set Pass Code.
  4. Select Pass Code, then enter a four-button code using the X and Y buttons, triggers, bumpers, and directional pad on your controller.
  5. Confirm your code by entering it again.
  6. Choose a pass code reset question.
  7. Select Pass Code Reset Answer and enter your answer using either your Xbox 360 controller or a standard USB computer keyboard plugged into a controller port on your console.
  8. Select Done from the Set Pass Code screen, then select Done once more from the Console Controls screen. When prompted, select Yes, save changes to put your new settings into effect.
To reset your pass code after you've forgotten it:
  3. Enter an incorrect pass code.
  4. You'll be told that your pass code is incorrect. SelectReset pass code.
  5. You'll then be shown your pass code question and asked to answer it.
  6. Set a new pass code, following the directions in the previous section.
If you've forgotten the answer to your pass-code reset question as well as your pass code, call Xbox Customer Support at 1-800-4-MY-XBOX (1-800-469-9269).
A couple of years ago i made my xbox live account and accidentally set the family settings to high now that im using my xbox agian i cant really do anything on live since i dont remember my password or...
spacer.gifReset a Forgotten Pass Code
I put on a family timer on my sons xbox and i can remember the pass code
I have a 32" tv... I must have press a button... bcuz now my tv showing blue screen with a small picture in red of a key... can u plz help me how to remove this and get my regular cable tv back on...
Hi msvkam
To answer your question;
You probably have the parental lock on,
Here`s the procedure and factory default code to unlock it:
Pass Code Menu
This menu allows you to change the access code for the Parental Guide
functions of the TV set. Pressing the .Menu. key when Pass Code
Control is highlighted. This will turn on or off the Pass Code function. With
the Pass Code function ON, you can also change the Pass Code. Use
the down arrow key to highlight .Pass Code,. then enter the new Pass
Code using the numeric keypad. Press the left arrow key when finished.
1. The factory default pass code of 6688 is also the override code, in case you forget your new pass code.
Hope this help,
Cheers
We have forget our familysetting passcode give us a code immerdiatly
Here is what you can do
2answers
Need pass code for bluetooth SGH-A867
just type any number like 01........the device whom you r connecting it will also ask for code type same code and here u go
Nov 24, 2009 • Cell Phones
Mad Catz PS3 Bluetooth® Headset Wireless Headset Logo
Top Mad Catz Radio Communications Experts
eradiostore
eradiostore
Ekse
Are you a Mad Catz Radio Communication Expert? Answer questions, earn points and help others
