Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
I HAVE A CARRIER GAS FURNACE APPROXIMATELY 10 YEARS OLD. IT WAS WORKING FINE LAST FALL. I JUST STARTED USING IT AGAIN AND NOW ITS STARTS UP AND THEN STOPS, STARTS UP AND THEN STOPS? IF I PLACE THE HEATER ON "ON" INSTEAD OF "AUTO" IT RUNS FINE. BUT WHEN I PLACE IT ON "AUTO" IT RUNS AND STOPS, RUNS AND STOPS IN 15-30 SECOND INTERVALS???? HELP!
Posted by wwarden on
Anonymous
  • 534 Answers
You may need to replace the thermostat or the thermostat batteries if applicable. To replace the thermostat follow the instructions on the new thermostat. Make sure to set the thermostat to the gas setting(see instructions) this should cure your problem. Good Luck on the repairs
Dave
Posted on Jan 05, 2010
True air heat tries to start then goes to gas.It worked fine in the fall but it is now -5F
Do you have a heat pump and gas furnace setup? Or is it electric and gas setup.
To me it sounds like either configuration issue its electric and gas, but if its heat pump/gas the furnace is defaulting to gas more then likely on the outside air temperature, usually most heat pumps only heat good down to 10 degrees F.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Nov 18, 2013 | Coleman Heating & Cooling
I have a 10-year old Carrier Gas pack Model #48GS024060301. Turned on the heat for the first time this season and the unit did not turn on. I was able to turn on the house circulation fan and since it...
If the induction motor ain't going I would look for a blown 3 amp (purple) fuse on the control board. If that was good I would check if any of the roll out switches were tripped. If a rollout switch was tripped check or air restrictions somewhere.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 17, 2010 | Heating & Cooling
Why does my furnace gas valve keep going bad
Check the ground wire to the gas valve or the wire in the middle of the gas valve that says mv--pv, and that is a ground..
Dec 19, 2009 | Heating & Cooling
Carrier Gas Furnace runs fine randomly stops blowing LEDs flash
That blinking light may be the diagnostic light. Count the blinks next time it fails. Carrier units will have two different blinks depicting the error code such as one blink followed by a pause than 3 blinks giving you an error code of 13. Then look at the wiring diagram, it will have an error code chart telling you where to start with your diagnosis. You already know that if you remove the cover it erases the error code, so look thru the small window first.
Nov 30, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
1994 Carrier 58 PAV
sounds like the relay for the unit may be bad, usually if a blower motor goes it stops or has a very loud humm and only goes slow
Aug 03, 2009 | Heating & Cooling
Knock Noise When Carrier Furance Starts Up
have the ac company check the actual blower wheel itself it may be slowly coming apart
Apr 20, 2009 | Carrier Heating & Cooling
Furnace runs OK, but blower runs again a few seconds later
Could be a defective thermostat in the plenum.
When a gas furnace shuts down the fan(blower) will run until the plenum cools to the safe range. Usually 1 and 1/2 minutes.
Intermittent operation is a defective thermostat or relay.
Mar 11, 2009 | Carrier Heating & Cooling
Gas furnace false start
Check the filter and/or air flow in general. It may be over heating.
Feb 25, 2009 | Heating & Cooling
Extreme heating bills
easy way to fine the high usage is to turn everything off and watch your meter and have someone start turning thing back on and watch for the most usage of power
Jan 25, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Weathermaker gas 8000 will not ignite
Your hot surface igniter may be bad. It may be cracked which would prevent it from starting the burner flame.
May 21, 2008 | Heating & Cooling
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
273 people viewed this question
Top Carrier Heating & Cooling Experts
Dennis Boxerman
jdthefixer
Marvin
Marvin
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
