Question about Kenneth Cole Chronograph Watch for Men
Kenneth cole k3771, is the self-wind function working?
I seem to have to give the watch a couple of manual winds a day. Is that typical of this watch?
How can I know that the self-winding function is working?
Posted by ewags1993 on
David Tolond
    President:
  • 2,501 Answers
Self winding watched should not need to be wound as long as they are being worn.
To tell if the self winding mechanism is working, hold the watch close to your ear (hold it vertical, as though it was on your wrist) and rock it gently. You should be able to hear a ratchet operating (a soft clicking noise).
I can't help thinking your suspicion about the mechanism having failed, sound very likely.
Posted on Jan 07, 2010
Manual
goto this website
http://www.genevawatchgroup.com/
Click on customer service, scroll down the center of the page untill you get the user manuals, your manual is there.
let me know if you need anything else.
Thanks,
Ekse
Jul 27, 2008 | Kenneth Cole KC1104 Wrist Watch
How to set day on kenneth cole new yor ks1004? thanx
Click on this link to a manual. They make one manual for all their watches. Kenneth Cole Manual
Aug 25, 2011 | Kenneth Cole Leather #KS1004 Watch for Men
I have a Kenneth Cole Reaction Watch KC 1170. I can not get the watch to run. It is brand new.
I have looked at the KC web site and most of the instructions don't give model numbers., so it is impossible to see if any of the instructions listed refer to your watch.
(if you go to http://www.genevawatchgroup.com/ , click on customer service and then scroll down,you will see KC instructions).
Isyour watch automatic? If it is, then it needs to be shaken (gently) from side to side for a minute or two to wind it up.
If it is a quartz type and you have pressed the winder into the home position and it still doesn't start, take it back and ask for a replacement.
Apr 16, 2011 | Kenneth Cole KC1170 Wrist Watch
Just got a KC3775 and it has stopped working within a month. what could have gone wrong?
Did you leave it off for a few days?
Are you aware that automatic watches only run for 2-3 days before they stop if they are not worn?
To get it going again you can either hand wind it or gently shake it from side to side for a while.
If this does not work, I suggest you return it to the supplier under the warranty.
Aug 17, 2010 | Kenneth Cole Skeleton Subdial Automatic...
I bought it new and then a few weeks later the battery seemed to stop. I did not wear it often. I heard some watches do not use battery and function with the movement of one's arm. Is this the case for...
If the watch is a self winding type, then it generally says "automatic" on the face. These will run for about 2-3 days if they are not worn, as the self winding action only works when the user is moving).
Battery driven watches should run for at least a year before needing a replacement, so if it has stopped already, it could be self winding or manually wound type. Some self winding watches can be manually wound so you could try this to see if it starts.
Aug 14, 2010 | Watches
My watch simply stopped working. It refuses to work regardless of how much I wind it. Where can I go to get it fixed?
www.watchrepairusa.com/kenneth-cole/watch-repair
The best place to send a watch is to the original vendor as they can keep any warranty in tact also. KC has a great watch repair.
Jul 15, 2010 | Kenneth Cole Automatic KC3773 Watch for...
Is it good to change watch movement to a battery ?Watch was overwound.
There is no such things as over winding a watch. If it is not an automatic watch then the watch will wind until it stops. If the watch does not run then something else is wrong.
If the watch is an automatic then about 30 winds will fully wind the watch. But, you can continue to wind the watch forever. It will never stop winding. Again, if it does not run after being wound there is something else wrong.
To fix your watch you need to have a qualified watchmaker repair it for you.
Hope this helps,
Ken
www.yellowstonewatch.com
Apr 08, 2010 | Kenneth Cole KC1104 Wrist Watch
Setting day/date on kenneth cole dual time watch I have a Kenneth COle KC1336 watch with analog hands, 2 digital displays, and it is also a stopwatch. Can't figure out how to change the day/date.
first, unscrew the stem lock. Then you can pull it out to the first "click". That is the "manual wind mode" if for some reason the auto-wind is not working due it has run all the way down. Pull it out again. That is the time set mode. The next "click" (pulling it out again) is the date set mode. Once you have them set, push the stem back in (past all clicks) and then re-screw the stem back to the lock position.
Aug 21, 2009 | Watches
Kenneth Cole Chronograph Watch for Men Logo
607 people viewed this question
Top Kenneth Cole Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
