Question about Xact Communication XTR1 SIRIUS Radio Receiver
Have two Xact XTR1 receivers in my home. Each connected to a separate antennae. 3-4 weeks ago when turning one on all it would do is light up the Sirius screen and beep and then the screen would go dark then light up again beep and do the same thing over and over. The other unit would work just fine until a few weeks later it started doing the same thing as the first one. My home is located in Brewer, Maine and Sirius tells me they are not having a signal problem in Maine. It seems strange to me both units would act up the same way within a few weeks of each other??? I really miss Sirius and so what can be done?? Thank you to any one who can help !! RB
Posted by brody240 on
Keith Fox
  • 641 Answers
It appears to be a common flaw with this model.
"all of a sudden the thing starts intermittently rebooting itself. Then it stopped receiving any audio, even though the display indicated that it was tuned in." -dissatisfied custom complaint.
Hopefully you will be able to return the device, although I have seen online a lot of people not getting theirs from the manufacturer. It appears to be a total loss and I am sorry to inform you of this information.
I wish it was as simple as a dead battery, have you checked? Please let me know if there is anything else I could help you with, or have any other questions I could try to help you. If you enjoyed my reply please don't hesitate to rate it with the "blue thumbs" (granted the news is upsetting).
Posted on Jan 06, 2010
What is the price of a XTR1 xactStream [Jockey Sirius Radio & An Antenna
These show up on e-bay all the time; I suggest you look there. Regards.
Jul 08, 2014 | Xact Communication XTR1 SIRIUS Radio...
Xact xtr1 turns on then off
Hi try replacing the phones battery and see what happens.
Thanks!
Jan 05, 2012 | Xact Communication XTR1 SIRIUS Radio...
Metal prongs on the antenna wire that plugs into the back of my Sirius radio have broken off. Can they be replace?
There are a couple of different ways the antenna connection can break. Docks and antenna replacements are available, though the actual prong itself may be difficult to track down.
Jun 15, 2011 | Xact Communication XTR1 SIRIUS Radio...
Problem with Xact Communication XTR1 SIRIUS Radio Receiver
Turns out the radio isn't broken after all. In my research on your site I ran across a user who said he/she just plugged their radio in, turned it on and waited. I tried that and after a couple of minutes of a Sirius logo screen, then a blank screen followed by a high pitched beep the radio started playing again. I then remembered that one of the last things I input with the remote before the radio stopped working properly was mistakenly selecting an unwanted prompt on the AutoShutDown menu. When the radio finally came back on I selected Factory Default to reset all functions and now it operates properly. Thanks for the help.
Mar 28, 2009 | Xact Communication XTR1 SIRIUS Radio...
Satellite radio
I have several 'ghettoblasters' that fit this unit if interested --- Frank
Jul 14, 2008 | Xact Communication XTR1 SIRIUS Radio...
No antenna detected
More than likely, it is the antenna. Sad to say, but the Sirius antennas go bad very easily. Make sure there is no undue pressure on the antenna wire itself, as that can aide to premature failure. Bad antennas are the number one reason for the unit to read 'antenna not detected.' I have seen plenty of the antennas go bad and they were not misused one bit. If you contact Sirius, they're usually pretty good at understanding the misfortune of losing your paid service. Sometimes they'll ship you out a new antenna.
May 11, 2008 | Xact Communication XTR1 SIRIUS Radio...
Sirius XTR1 Receiver cycles on dog screen with beep - keyboard locked
Hello, I had the same problem with my xact xtr1 and I was advised by xact that they have no repair process in works and most likely wont. They did say let it run for 10 minutes and once you have a menu switch to factory defaults which proves to be a worthless fix. I would have to pay $39.95 for a new radio...horrible customer service. The bright side is that Sirius will not charge me the $75.00 transfer fee as a good faith gesture. I have decided to switch to another radio and leave the Xact brand out of the equation, if there is no upgrade or modification to the existing equipment why set yourself up for a future failure.
Aug 05, 2007 | Xact Communication XTR1 SIRIUS Radio...
CANNOT READ ANTENNA
I had a similar type problem where i have a lifetime subscription and my XACT VISOR XTR3 unit had a faulty power connection that was driving me nuts. i decided to try and swap out the internal receiver component with a new unactivated unit i bought on ebay. (all the types are out there and pretty cheap even for new)
in opening the new one up i found the only difference from unit to unit is the receiver brain inside the unit, and it is relatively easy to swap out the brain into the body of a new unactivated unit. just four small screws and carefully pull the brain out of the long multi-pin connector. i put the old brain into the new carcass, screwed it back together and it works like a champ. just have some patience in figuring out exactly how your particular unit comes apart, and you will need small screwdrivers and either a small allen-key set or torx set - my old unit had the allen-key screws on the outer case and the newer one had torx screws.
Aug 10, 2006 | Xact Communication XTR1 SIRIUS Radio...
Xact Communication XTR1 SIRIUS Radio Receiver Logo
Top Xact Communication Audio Players & Recorders Experts
Are you a Xact Communication Audio Player and Recorder Expert? Answer questions, earn points and help others
