Two problems, one is a bad thermostat on zone 2. The second is the boiler. The inducer fan energizes causing a pressure switch to engage. This pressure switch energizes the ignitor. If the ignitor does not get hot enough, it will cycle again all over. The cheapest route to take is to check all hoses going from fan housing to pressure switch looking for bad connections or leaks, the second thing to do is to replace your ignitor (time for it anyway).
Posted on Jan 06, 2010
Mar 06, 2013 | Cars & Trucks
Yes -
Microsoft have actually made quite a lot of noticeable changes to the start
screen in the new WP8, such as;
They've
kept the live tiles but they now have support for 3 sizes which lets you
customize your screen much more.
You
can choose from a pallet of 20 colors to customize your screen.
There
is now multiple screen sizes and a range of resolutions to choose from.
You
can change your lockscreen background and even choose which apps you want to be
on the background.
Nov 06, 2012 | Microsoft Windows Phone 8
Sep 19, 2011 | 2004 Subaru Impreza
May 11, 2011 | Honeywell Heating & Cooling
Oct 23, 2009 | Dryers
Oct 03, 2009 | 2007 Infiniti G35 Sedan Sport Sedan
Aug 24, 2009 | Pioneer PDP-5020FD 50 in. Plasma HDTV
Mar 30, 2009 | Dodge Ram Cars & Trucks
Oct 05, 2007 | LG 42PX4DR 42 in. Plasma TV
330 people viewed this question
CLARIFICATION:
First - a clarification for those wishing to use this post to help debug similar problems. My heating system is hydro-air and zones 1 and 2 are each managed by a separate air handler.
UPDATE:
HVAC guy came out today. Felt it was a sticky relay in the zone 2 air handler and replaced it. Items leading to this decision were:
1. Boiler appeared to be working since other zones were not having any problems (though the occasional cycling of the boiler is still a mystery)
2. Hot water was getting to the Zone 2 air handler - so the pumps were working as well.
3. Air was not blowing from the handler when it should have been. Turning the stat to manual fan would begin blowing hot air, but when set to auto - sometimes would work, sometimes wouldn't
4. Turning stat off and back on would sometimes fix the problem - probably because it would reset the relay.
Regarding the boiler cycling issue - recommended a boiler cleaning and keeping an eye on it to see if the ignitor or flame sensor is going bad.
