Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Fisher & Paykel dishwasher beeping with red light indicator. Won't stop unless unplugged. Doesn't work, (won't drain when it did work), can't change cycle. Have not used it in a long time due to problems
Posted by carolephx on
Anonymous
    New Friend:
  • 8 Answers
Try pulling out the bottom drawer and check to see if there is a puddle of water around the circuit board, if so it will make it do a lot of wierd things.
Posted on Jan 31, 2010
Our 2 draw dishwasher stops mid cycle once or sometimes several times. The red light comes on and it bleeps until we press the start button then it will continues the cycle.
The red light and beeping indicates a fault. The fault code number will be indicated in the display or by other LEDs being lit. If you post back with the details of the display we may be able to help you.
Machine stuck in drain mode, beeps, can only turn off at powerpoint.
Your motor controller board is faulty
needs repair or new/recondition board.
Fisher and Paykel GWL11 Top Load Washer starts but drum won't turn, it twitches and beeps then turns off with solid beeps
Hi ken
Can you turn the bowl & agitator by hand.
If it can't turn by hand, Your seal & bearings need replacing.
Machine beeps 3 lights on and won't pump water out
can you take a picture of the lights that are on so I can work out the error code thanks
I have a Fisher and Paykel Smartdrive 9 washing machine that won't fill. It starts then stops and continues to do so, then stops altogether and beeps. Can anyone help??
The error code is displayed when its beeping.
I don't know the error code, so It can only be three things,
Out of balance switch,Lid magnetic reed switch,Or Rotor position sensor,Your error code would help me work out witch one of these are faulty. to work out your error code look at picture below.
Add up the lights that are on.
Hello where can I find the error codes for a fisher and paykel smart drive 703? It stops usually during s pins cycle (well it looks like it's trying to spins and it won't start).so it stops and...
Hi - what would youlike to know - we are forbidden by contractual & copyright laws to provide what you seek..
Besides you are lucky if parts for the 703 is still in existence - only savvy techs could salvage those as you have to modify wiring & components for it to work. I have only done this once in the Pacific islands some years ago.
The dishwasher will start for two sec and then they both stop and a red light comes on and starts beeping with motors running.
This indicates the flood switch has been tripped. The video in the link below explains how to access and repair single and double drawer fisher and paykel dishwashers. Its a really good Fisher Paykel dishwasher repair video it really helped me.
Fisher Paykel Dishwasher Repair Video Link
5helpful
2answers
Hi Both drawers show error F1 flashing beeping with rinse light on and both pumps run after power is applied to machine
F1 error indicates flood switch in base has activated, meaning machine has leaked. This causes machine to drain continously, and can only be stopped by switching off power. Not easy to fix if you don't have experience- bottom drawer has to be removed to access flood switch, then machine needs to be test run and checked for leaks. Best to call the professionals!!
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Marvin
Marvin
Paul Bade
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
