Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Efx Logo
Posted on Jan 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Por favor mi xenix 1202 se daño y necesito el
Por favor mi xenix 1202fx se daño y necesito el diagrama electronico ayudenme
Fred Yearian
Level 3:
  • Behringer Master 5,603 Answers
  • Posted on Jan 06, 2010
Fred Yearian
Behringer Master
Level 3:
Answers
5603
Questions
Helped
2249483
Points
16163
Behringer does NOT supply diagrams except to their authorized repair facilities... I know as I have tried and I wind up repairing without diagrams/schematics most of the time. In some cases I have traced out the circuitry.
FORTUNATELY mixers are fairly simple circuitry.
MOST problems I have encountered were due to defective sliders and in one case liquid had caused circuit traces to short and the burned area had to be carved out and jumpers placed where the traces were missing.
the circuitry repeats several times so one can look at adjacent channels to compare damage.
I do not know your language, but reconized what you are asking from the few words I trnaslated.
2answers
Korg X50. When switched on, why does it indicate: 'Waiting for the data from USB'?
Sounds like loss of memory\programming.Go to Korg website for download.
Oct 13, 2019 • Korg Music
My behringer eurodesk sx3242fx has a problem with the MAIN OUT XLR (L&R)....LEFT side is not working what is the problem?
Hi Ezra, for the failure you describe, you may have a problem with the Main Insert connectors, more presumably on the left, this connector has the function of interleaving some type of processor in the stages of the master L and R, and has some contacts internal that get dirty and produce false contact in the passage of the output signal
Try cleaning it with some contact cleaner, put a small amount of cleaner and with the help of a plug, put it on and take it out several times in order to make the cleaner work, do the same with the right channel, because the same fault will appear. , sometime
If this does not work, you would apparently have problems with the left master dimmer potentiometer on the corresponding electrical circuit
I sent you the link to download the user manual of your Behringer
I hope you serve my suggestions and manage to make the left exit work
Greetings Franco Dosil
Hola Ezra, por la falla que describes, puedes tener un problema en los conectores Main Insert , mas presisamente en el Izquierdo, este conector tiene la funcion de intercalar algun tipo de procesador en la etapas de los master L y R, y cuenta conunos contactos internos que se ensucian y producen falso contacto en el paso de la se?al de salida
Prueba limpiarlo con algun limpiador de contacto, pon poca cantidad de limpiador y con la ayuda de un plug ve colocandolo y sacandolo repetidas veces a los efectosn de que el limpiador actue, haz lo mismo con el canal derecho, porque ya le aparecera la misma falla, en algun momento
Si esto no da resultado, aparentemente tendrias problemas con el potenciometro atenuador master Izquierdo on el circuito electrico correspondiente
Te envio el link para que descargues el manual de usuario de tu Behringer
Espero te sirvan mis sugerencias y logres hacer funcionar la salida Izquierda
Saludos Franco Dosil
http://www.manualsbase.com/es/manual/downloadmanual/119881 https://manualsbrain.com/es/manuals/809021
En el pa korg 500 de error aparece os lectura de archivos Que Se Puede HACER
Carlos Hi
despues de formatear el equipo todo tiene que volver como recibistes el pa 500 nuevo de fabrica
Qsc k12 schematic
Tengo el mismo problema, ella suena pero al subir la potencia se apaga, supongo es una soldarura mala, si es asi por favor especificame adonde y si es otra causa favor indicar.
Agradecido de ante mano!
3helpful
.necesito un diagrama esquematico para europower MPX 5000
.necesito un diagrama esquematico para europower pmp5000 pmp6000
Quiero conectar la guitarra
Se necesitan dos cuarto de pulgada a los adaptadores de RCA. El uso del adaptador, conectar la guitarra a la entrada y la salida a su amplificador o dispositivo que desee.
Por favor, perdone mi espa?ol, ya que no lo hablan.
I have the Eurolive B212A speaker,and the Xenyx 1202fx.I want to play my Ipod using this set up.Please help with connection
The Ipod is stereo and your speaker is not, so don't expect stereo.
Find a 1/8 inch stereo cable that splits the two channels into individual cables and enter those into two channels of the 1202 mixer. You might find a cable that goes from the 1/8 inch stereo and splits to two RCA type jacks which you have to either find RCA inpouts on your mixer or get two RCA to 1/4 inch adapters.
Crank the pan controls clear to the left on those two channels. Run a cable from the 1202 left main out to your speaker input.
Adjust the controls as needed.
Top Behringer Music Experts
john h
Are you a Behringer Music Expert? Answer questions, earn points and help others
