Question about Pride Value Line Revo Scooter 3 Wheel
Revo 3 wheel: will not hold constant speed; batteries recently replaced but did not fix problem
Posted by daria85304 on
Rob Hill
  • Pride Master
  • 1,414 Answers
Hi, there could be a number of issues,
First check the speed pot, try moving the throttle lever in the upwards or downwards direction while going forward, if the scooter starts to pick up again then the speed pot is worn and needs replacing.
if the motor has brushes check them, make sure they can move freely, some times they stick and cause intermittant speed problems, check the battery conections and make sure they are tight.
If this helps please vote.
Regards
GeWiz.
Posted on Jan 06, 2010
  • Rob Hill
    Rob Hill Jan 19, 2010
    okay , now the next problem to look at is the fiiting of the battery case to the scooter, if I remember correctly the contacts are string loaded, Rough up the contacts but be gentle.
    If the rear comes away from the main frame check the contacts there, they can be troublesome and there is resistance that would explain the loss if power etc.
    Regards
    GeWiz.
My Pride Revo Mobility scooter needs a new gear box.
never said how old it is,cant give you a good answer without knowing.
Sep 13, 2012 | Pride Mobility Revo 3 Wheel Scooter
Scooter shows "speed pot error". How do I fix that?
You will more than likely need a new speed pot but some are connected to the throttle pot as well so it could be that which is at fault. Could also be wiring or worst case, control box but this is unlikely.
Feb 20, 2010 | Pride Value Line Revo Scooter 3 Wheel
Will not go very fast about half speed
If the battery is charged fully, check the speed knob on the steering console. It is probably turned too low.
Feb 18, 2010 | Pride Revo 3 Wheel Travel Scooter
I just bought a revo three wheel scooter and it stopped going in reverse.
hi, the first thing to look at is the speed pot (wigwam), sounds like either it come loose so the pot is in the incorrect position or the track inside the pot is damaged or the wire for the reserse side has broken or come away.
Jul 25, 2009 | Pride Value Line Revo Scooter 3 Wheel
Pride Value Line Revo Scooter 3 Wheel Logo
203 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
