Televison & Video Logo
Posted on Jan 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Universal remote codes do not work for vcr device. Tried all codes located in universal remote code index for emerson vcr, none are working correctly.
Anonymous
Level 3:
  • Master 476 Answers
  • Posted on Jan 05, 2010
Anonymous
Master
Level 3:
Answers
476
Questions
0
Helped
101225
Points
1473
You do not mention what brand of universal remote you are using but if you have the programming instructions for the remote, look up and folow the instruction for the code search procedure, this procedure when performed correctly will put out all the codes programmed in the remote, if this does not do it for you, then you will need another brand of universal remote.
8helpful
2answers
I recently purchased a "TDE SYSTEMS" jumbo
sanyo tv codes are 0506,0311,0612,0002,0428,0802,0412,0619 and emerson vcr are0626,0126,0826,0227,0327,0630,0632,0134,0037,0625,0924,0324,0128,0228,0428,0528,0447,0247,0724,0325,0526,0726,0027,0527,0827,0927,0628,0530,0830,0731,0634,0735
Emerson EWD2004 need code for Emerson Jumbo
Code # 20675 worked perfectly for me for using this same combo device.
Emerson Jumbo universal remote code search feature does not work
The Learn feature on this remote worked well for me. It takes a little time because you have to teach it the code for each button but it worked well for my cable remote, which I had never been able to get any universal remote to work with.
1helpful
I CAN'T GET MY UNIVERSAL REMOTE TO WORK ON MY 13 INCH EMERSON TV/VCR COMBO. CAN ANYONE HELP ME?
Some universal remotes will not program for combo devices using the TV code. You might try using the VCR code and see if it takes. Some operating functions might not work.
1helpful
2answers
Remote control code for 32 inch lcd EMERSON TV
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
1helpful
2answers
Need codes for rca universal remcon to emerson vcr and need codes for emerson vcr and coby 224 dvd
Try these codes for the emerson:
Code 003 for Emerson VCR Code 007 for Emerson VCR Code 012 for Emerson VCR Code 014 for Emerson VCR Code 015 for Emerson VCR Code 021 for Emerson VCR Code 024 for Emerson VCR Code 025 for Emerson VCR Code 026 for Emerson VCR Code 029 for Emerson VCR Code 031 for Emerson VCR Code 032 for Emerson VCR Code 033 for Emerson VCR Code 038 for Emerson VCR Code 041 for Emerson VCR Code 054 for Emerson VCR Code 065 for Emerson VCR Code 116 for Emerson VCR Code 130 for Emerson VCR
and I wasn't able to find any for the dvd player :/
20helpful
4answers
Need code for Emerson TV,DVD,VCR Combo
I don't know if you guys even need this advice anymore, as it's 1-2 years late, but if your universal remote has a VCR setting, the Emerson 13" CRT TV/VCR combo I have operates under that mode.
The code I used was 002. These may also work: 278, 184, 479, 000, 121, 211, 037, 043, 061, 208
Remember, program your remote as if you were setting up a VCR (and NOT a TV). For instance, on my GE universal, I hold the "code search" button down until I get a steady light. I hit VCR, and then I entered 002. Works like a charm.
14helpful
5answers
Emerson remote for emerson tv/vcr combo
Emerson TV codes 0154, 0236, 0463, 0180, 0178,
0171, 0623
Emerson TV VCR Combos 0479, 1479, 1278
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
here is the maual for your remote:
http://www.ofausa.com/remote_manual/URC4...
3answers
"Emerson TC 1351" universal remote trouble
I'll sell you a universal, just let me know if you want it
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
