Question about Nokia 6600
Nokia 6600 startup failure
When i switch on my nokia 6600 mobile phone, the following message appears:"phone startup failed. contact the retailer."
the phone is 4 years old. there has not been a similar problem earlier.
Posted by rkn42008 on
Anonymous
    New Friend:
I have the 6600, last week the mobile couldnt work. phone registration failed contact retailer message displays. i have many messages in that mobile. i contacted the retailer, but the retailer told only solution is flashing the mobile. shall i get back my messages in that mobiles please help me
Posted on Feb 01, 2010
Yu gal
    New Friend:
Don't mind ek noya mobile purana mobile ko to do sala bhikhari
Posted on Dec 23, 2012
I dont know my lock code sir please tell me sir imei no 353777005895079
1 - Switch on your Nokia 6600 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6600.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6600 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 6600 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 6600
Nov 15, 2011 | Nokia 6600
When i power on my n95 8gb its writing : phone start-up failed. contact the retailer . what i must do
hi
there must be software corruption in your mobile. kindly format your phone . this will able to fix your problem if still having this problem means then there must be some hardware problem in your mobile. kindly ask your service provider to fix this problem. but formatting your phone will fix your problem
thank you
Dec 20, 2010 | Nokia N95 Cellular Phone
Phone start up failed contact the retailer
Usually can't solve this issue with home remedy. Attempt to call service provider or do as it says...contact retailer.
Apr 14, 2010 | Nokia 6600
PHONE STARTUP FAILED
Your firmware seems to be corrupt. get it re-installed. I suggest that you get it done from Nokia Care and not yourself from the net.
Jul 30, 2009 | Nokia 7610
Phone startup failed Contact the retailer.Nokia N91
Problem: Nokia 7610 startup failed contact the retailer
Solve: You Need to format your mobile and this is the way
First of all Turn Off Your Mobile Phone
[ format = power + press & hold call + * + 3 ]
Jul 19, 2009 | Nokia N91 Cellular Phone
Need to formatting nokia 6260 mobile
Switch the phone off. Hold the following 3 keys down and turn on:
3 , * and the green phone key
This will reset back to factory defaults but will completely wipe the phone of all data (your contacts, messages etc). Just follow the onscreen instructions - it will prompt you for your security PIN, the default is 12345. Good luck.
Mar 23, 2009 | Nokia 6260 Handheld
Mobile startup failed . contact the retailer
hi,
Your phone's memory card must be infected with virus or has some fault. Please remove the memory card and try to start the phone again. If it goes through, please back up the data in your memory card and format it. In most cases, this procedure solves the "Phone start up failed. Contact the retailer" error.
I'd advice you to format your phones internal memory as well, it will flush out any errors present. save your "phonebook" data somewhere and Make sure your phone's battery is fully charged if not plug the charger in and proceed. NB: interrupting this process might render your phone useless. So, be careful.
To format press *#7370# it will prompt you for security code, enter it and the phone will reboot. Your phone will be reset to "factory settings."
Jan 13, 2009 | Nokia 6600
I have trouble with my Nokia 6600 phone
Well your phone needs to be serviced as it has a Boot problem..jus take your mobile to any Nokia customer care for service..Thank you!!
Aug 02, 2008 | Nokia 6600
Phone startup failed contact your retailer
first try u r mobile to start safe mode
how to start safe mode :
switch off u r mobile & then press & hold pencil key and press switch on botton after start it will ask you 4 digit pin code enter pin code take contacts back up in simcard then hard format your cell
how to format:
switch off cell
then press & hold 3 keys (*+3+green boton"calling key")
then press & hold switch on boton
till screen will display "formmating"
make Shore battry is full charge u r phone will work fine.
Jul 13, 2008 | Nokia 6600
Start-up Failed Contact retailer
try this tricks....
If you encounter situation like below on your 6670,
1. Blank screen phone unable to reboot.
2. Phone only able to boot-up to "Nokia" word screen.
3. Install some program but not able to uninstall it after that.
4. Error messages such as "Child Installer" keeps popping-up.
Do a Full phone formatting on your 6670! as steps below,
1. Make sure you have at least 3/4 charge of battery power left.
2. Backup your contacts list and personal files to MMC memory card.
3. Switch-off your 6670phone.
4. Press and hold 3 keys;
Green dial key, * (star key) & no. 3 key and then press the power on/off to swtich on the 6600 phone.
Remember, do not let go all of the keys and hold keys until you see a NOKIA turns to white screen LCD!
5. After a few minutes when the Full phone formatting completed, your 6670 will back to original system and factory settting.
All apps installed & not of the phones' default will be lost. If you did a backup on your mmc, you can restore it back to the C drive again.
but still you have the prob. Contact Re-tailer
go to the Cellphone Shop nearby and try to re-program your mobile or Hardware...
Thank you for rating this Tip.
Jan 20, 2008 | Nokia 6670 Handheld
Nokia 6600 Logo
394 people viewed this question
Top Nokia Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Resolution IT Dubai
Resolution IT Dubai
Marvin
Marvin
