Falcon GGO 211 propane 11 yrs old, rh oven lights but will not heat up. Falcon say FSD is needed but no parts available due to age. Any ideas how to fix it?
SOURCE: Gas oven not heating to temp
You more than likely have a defective oven sensor. For some reason the sensors tend to go after a few years of use. It is in the upper right or left hand corner and looks like a probe sticking through the inside back of the range. When you open the door you just look towards the top back left or right corner there are 2 screw securing it to the back. Gently pull it forward. You will see a couple of small wires feed into as you pull it in. On most you will see a plug in connector come through the hole if not you may have to just splice the new one in.
SOURCE: Kenmore gas (propane) range Model #119.7488810 18-20 years old
you have a bad oven/bake ignitor, althoough you see ther glow, its not "hot" enough to allow gas flow or ignition, very common issue, 2 screws and 2 wires, probably about $75, service company gets min $225..
SOURCE: How do I change an orphase from a natural gas to propane?
If you have converted the burners and the regulator, all you have left to do is the oven and broil burners. (for self clean oven model you posted under)
Let's do the broil burner first. Open oven door and look up at the broil burner. At the back of the oven you see the tube that the gas flows through to get to the burner. At the base of this tube is an air shutter opening, and right there you will find a brass nut with a hole in the center of it (the burner's orifice). Use a 1/2 inch wrench to turn the nut three full revolutions clockwise looking at it from the burner side. It is easier to turn it twelve 1/4 revolutions.
Now, do the same to the main burner by removing the storage drawer, remove the one screw holding the metal plate so you can get at the base of the burner, and do the same to that orifice. Do not over tighten the orifices.
SOURCE: Kenmore propane stove (16 yrs old). Oven quit working yesterday
is ther a slight propane smell around the stove?i'm thinking your oven pilot light got blown out
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
